'98 V70 FWD Stick, Non-Turbo -- Starting Woes II
- E Showell
- Year and Model: ‘07 S80 3.2
- Has thanked: 37 times
- Been thanked: 111 times
Re: '98 V70 FWD Stick, Non-Turbo -- Starting Woes II
Additional symptoms -- Went to start today. In the past few weeks the car had been missing and the check engine light was on, but it would still start (except for the occasional total no go). Now when I attempt to start it, it fired up with an incredibly rough idle then died. On attempting to restart, seems the rough idle is interfering with its ability to start/run.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
'95 855 auto (sold)
- E Showell
I think the problem is solved. On the advice of my retired Volvo mechanic friend on my most recent no start condition, I took a set of jumper cables and went from the negative battery terminal to a bolt on the block. Car started right up thereby confirming that my on-the-cheap fix to the negative battery cable was not working full time. I have already obtained a replacement cable and will be installing same today. Thanks for all of your advice/suggestions.
Last evening's test drive confirmed problem solved. . . for now.
'95 855 auto (sold)
'95 855 auto (sold)
