ABS module - - needs programming?
TipTopTommyT
- Year and Model: X/C V70 - 1998
Thanks everyone.
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
It can be either. 95% of the time on a 96-newer model, it is the ABS module if it has not been replaced or rebuilt before. But I made one of the wheel sensors angry once in the snow. If your speedo still works for now, it may be worth it to clean the wheel sensors first.I have the light problem but the speedo works fine. Is this still a controller or could it a wheel sensor? I did have a boot problem about a year and a half ago.
'98 S70 T5
2016 Chevy Cruze Premier
jblackburn
Read (and clear) the codes from A3 as shown here and let us know what you find. When you do, please start a new topic with your codes.how would i get the abs light to go off on my 94 850?
http://www.volvospeed.com/CheckEngine.php
'98 S70 T5
Got a rebuild from Matty Moo ( Very quick I might add ) put it in and am now good to go on that. Thanks to you all and especially Matty Moo. Very quick and the most affordable around. Thanks again.
- Year and Model: Many Volvos
- Been thanked: 76 times
On a '94 pull the codes. The '95 and older modules are much more robust than the '96 and on versions but they can fail.
Post back the codes from port A-3 and post them back.
We will work with you from there.
The '94 is a whole different animal. Pull the codes from port A-3 and post them back.
If you have not used the onboard diagnostic system here is how you do it:
http://volvospeed.com/CheckEngine.php
That writeup is specific to the ECU but it works exactly the same to read the codes from port A-3.
- 802 Views
Last post by jimmy57
- 1993 Views
Last post by wingspan99
- 11 Replies
- 7338 Views
Last post by Vovoroom
- 391 Views
Last post by RickHaleParker
- 6130 Views
Last post by misha
