What makes my headlights fade?
Dull headlights, what's the cheap fix?
Red-Arrow
- Year and Model: 850 T5 1995
- Been thanked: 2 times
I do not recommend HID kids for reflectors, a Lens must be used to focus the light from the arc inside the bulb. Maybe you can find a company that does electro plating on your reflector locally. HID kits produce more heat and will further and faster damage your precious reflectors.
Life would be enjoyable if it wasn't so painful to live.
- Has thanked: 17 times
- Been thanked: 35 times
I did not change the lens or reflectors on mine when I did the HID kit- I have had no problems and the light produces is much better than stock.
JRL
- Year and Model: Several
- Been thanked: 16 times
03-04 C70 headlights are the best
Not only do they look awesome, you can actually SEE
(Unfortunately, expensive, at least new).
Red-Arrow
I did not mention lens but the fact remains the reflector has not been designed to collect the light from a HID bulb arc. Its very different from a filament and the plasma moves inside the bulb. Its creates a glare that is very annoying for drivers coming in the opposite direction. The light output is greater but not better in a meaningful way. We know that high temperatures whites light are not the best colour against a dark road, yellow is a far more useful colour against a dark road.MadeInJapan wrote:I did not change the lens or reflectors on mine when I did the HID kit- I have had no problems and the light produces is much better than stock.
JLR the V70 lamps look great. Did you have to modify them for mounting? or was it a straight forward swap around?
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
Nah, they won't fit an 850. There are some aftermarket projection kits, or E-code lenses that will help out an 850.
'98 S70 T5
2016 Chevy Cruze Premier
ojdorson
- Year and Model: 850R, 1996
- Been thanked: 3 times
Thanks. I might start by getting an HID kit and E-Codes and then having them aimed properly. I don't LOVE the look of those projection kits - especially not the black background ones.
- 1607 Views
Last post by FireFox31
- 3474 Views
Last post by ShadowDancer
- 1347 Views
Last post by FLXC90
- 865 Views
- 3959 Views
Last post by kashee77
