DIY: 98 V70 Brake Hydraulic Overhaul (Hoses, Seals, Parking)
This topic is in the MVS Volvo Repair Database » 1998 Volvo V70 Brake Hydraulics Overhaul
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2864 times
Been thanked: 1332 times
Post by matthew1 »
Thanks for the update, CN.
(I always remember which materials expand with heat as this: water expands when cold (think ice), most everything else is the opposite.)
Also -> Amazon link
instarx
Year and Model: XC70 T6 2011
Has thanked: 1 time
Post by instarx »
When using compressed air to push the piston out be careful not to have your fingers in the way. It hurts like the dickens if the piston comes flying out (don't ask how I know that). I've heard that it can break fingers, and I believe it.
2011 XC70 T6 - current
2017 Alfa Romeo Giulia Q2 - Totaled in 2022. Not my fault.
2011 XC60 - sold
2000 V70XC - given to a friend, wish I still had it.
Miltown
Year and Model: 1998 V70
Post by Miltown »
Just did mine thanks for the post it really helped. I have AWD and Turbo so the rear are different and easier to do than yours. It really helped to cut the brake hose first and then turn the hose end as opposed to the line end. IT saved the flange nut big time. I used vice grips on the flats of the flange nut when breaking it loose and then a flange wrench for loosening it up the rest. Also those rear seal kits aren't available at rmeuroupean anymore or anywhere else and you did yours just a few months back.You must have bought the last set. Thanks again the pictorial documentation is awesome.
paul
paul
'98 V70 awd
'83 BMW R80RT
Red-Arrow
Year and Model: 850 T5 1995
Been thanked: 2 times
Post by Red-Arrow »
I did this job last summer except the parking brake shoes inside the rear disc. I can appreciate how much trouble this job is. More credit to you for being able to take pictures as well. I have a stupid side SLR that can't fit into anything tight.
Life would be enjoyable if it wasn't so painful to live.
Year and Model: 2004 V70 2.5T
Been thanked: 504 times
Post by cn90 »
Miltown wrote:... Also those rear seal kits aren't available at rmeuroupean anymore or anywhere else and you did yours just a few months back.You must have bought the last set. Thanks again the pictorial documentation is awesome.
paul
Paul,
Did you do the whole 9 yards?
* All brake hoses AND
* Rebuilding all 4 brake calipers
Just curious.
Post by cn90 »
Miltown wrote:Also those rear seal kits aren't available at rmeuroupean anymore or anywhere else and you did yours just a few months back.You must have bought the last set.
You are right, at the moment rmeuropean does not carry the REAR rebuild kit (PN 270902).
But Eeuroparts.com has it.
Miltown
Post by Miltown »
Just the hoses and rebuilt the front calipers. The rear hoses are the longer ones for AWD and are very accessible. I have not bleed the system yet. I'm finishing up the CV boots ( the reason I started this job). If I can find the rear seal kit I would purchase them so I'm going to check out your link to the other site. What I have found is sites will say they have them and then tell you they are not available when you order them. Volvo doesn't even sell the kits anymore.
paul
'98 V70 awd
'83 BMW R80RT
Miltown
Post by Miltown »
Just checked and Eeurope.com doesn't have it either. The caliper is not that bad of a price though.
paul
'98 V70 awd
'83 BMW R80RT
kiss4afrog
Year and Model: 850 1995
Post by kiss4afrog »
[quote="cn90"]Another Note on seized nuts and bolts: whenever you see the metal line with the nut, expect it to seize after years in service.
- Spray WD-40 to areas that you will work on a few days ahead, then spray WD-40 again on the day of the work.
Don't bother with WD40. :roll: WD40 is a dry lubricant. Once it's sprayed it dries up. It's great for cleaning tools but is NOT a penetrating lubricant. I love PB Blaster. It works great on Minnesota salt corroded front end parts. It works better than liquid wrench my previous stand by but anything other than WD40 would be a better choice including motor oil !!
If it's really seized in place it sometimes helps if you can add some heat. A torch or if in a delicate area a soldering iron is better than noting. Heat up the joint and then wait a few seconds, then spray. That way you are cooling the joint with the lubricant and the cooling will literally pull it down into the joint. Let it cool all the way down and try again if it's really seized. Saved my butt many a time on brake lines and bleeders.
My two cents.
You can never have too big a Turbo !
matthew1
Site Admin
Post by matthew1 »
Bump just because this topic is so damn good.
Also -> Amazon link
