A hole on the top of coolant expansion tank
FlyingVolvo
- Year and Model: 2000 V70XC
- Has thanked: 51 times
- Been thanked: 73 times
Re: A hole on the top of coolant expansion tank
When I replaced my reservoir, the old sensor died too. You can mess with it, but it seriously is a very important sensor that I wouldn't want acting up. Just replace it!
2000 V70XC - 340,000 miles
2023 V60 T8 PE
2023 V60 T8 PE
I'll replace the sensor as FCP sells it for ~$15 I think. But since the sensor died frequently during replacement of the reservoir, is there any tip to avoid it? Or is it due to a slightly-different designed tank?ecbsykes wrote:When I replaced my reservoir, the old sensor died too. You can mess with it, but it seriously is a very important sensor that I wouldn't want acting up. Just replace it!
FlyingVolvo
Most of the time when it "dies" during replacement, it happens to be the original sensor, which in most cases now means it's at least 10 years old. I think the key is to unplug the electrical connection first when messing with the expansion tank. A lot of people tug at the tank with the level sensor still attached which likely damages the connection.
2023 V60 T8 PE
2023 V60 T8 PE
I should have disconnected the battery first then.ecbsykes wrote:Most of the time when it "dies" during replacement, it happens to be the original sensor, which in most cases now means it's at least 10 years old. I think the key is to unplug the electrical connection first when messing with the expansion tank. A lot of people tug at the tank with the level sensor still attached which likely damages the connection.
Must be the reason.
FlyingVolvo
I don't mean the car's main electrical power (battery). I simply meant the electrical connector for the coolant level sensor. If it's still attached, it has a tendency to get yanked on, damaging already very old wires.
2023 V60 T8 PE
2023 V60 T8 PE
- 762 Views
Last post by tryingbe
- 12 Replies
- 2433 Views
Last post by precopster
