there are 4 bolts that attach the condenser to the radiator. the lower ones are easy - both of them are looking right at you in the pictures that the OP provided.
the ones up top that jblackburn showed with the picture - you can get those out by using a universal joint extension if you undo the bolts on each side of the radiator.
Removing radiator trouble
volvo850955555
- Year and Model: 1995 855
Ok so I confused the radiator with the intercooler. The pics I have are from the intercooler, how do I remove that?
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
You want to remove the intercooler or the condensor?
The intercooler (for the turbo) and radiator drop down together, then separate once you've got it down and out of the car.
Is the condensor wrecked too? It looks bent, but is it still holding an AC charge? If you empty the charge, you'll have to replace that and the AC dryer and then refill the AC system. Ideally, the refrigerant should be evacuated from the system rather than just spraying it out.
'98 S70 T5
2016 Chevy Cruze Premier
volvo850955555
Does it matter if the ac condenser works or not? Can I just use it of it's broken or does it help cool the engine because I have not had working ac in my car for the past year
ojdorson
- Year and Model: 850R, 1996
- Been thanked: 3 times
I wouldn't ruin that condenser - just leave it there.
Here's the write-up I followed just last month - http://volvospeed.com/volvo_repairs_how ... ement.html
kcjones
- Year and Model: 1997 855 GLT 200k :)
Not sure if this is a good idea or not, but maybe remove it since the A/C doesn't work? Maybe get better airflow to the radiator and intercooler? That is, if it all mounts back up properly. I would've loved that extra space when I replaced mine. Just a thought.
- 344 Views
Last post by erikv11
- 2489 Views
Last post by yanga001
- 1182 Views
Last post by neworleans
- 3654 Views
Last post by t3yf5g
- 7198 Views
Last post by jalwlb
