The clutch switch is up forward of the clutch pedal - Im surprised you can disconnect it as on the 99 it talks to the ECU and usually uses logic to enable starting - it might just be an on/off though.
Marco - if your clutch switch is disabled, does your cruise control drop when you hit the clutch?
Yikes....
'remote starter terminal location' are the keywords I put onto the thread, I think.
Bingo
viewtopic.php?f=1&t=78989&p=425333&hili ... on#p425333
