Time for Regular Service Message Reset Procedures Topic is solved
Reset Volvo S60 Time for Regular Service message
gregbeanpe
- Year and Model:
How do you reset this message on an 02 S80? Is it the same as the S60 posts say?
- Has thanked: 17 times
- Been thanked: 35 times
I think it is. All the instructions I've seen are for MY (model year) 2002 and it doesn't specify which model. Give it a try and see.
Please add my THANKS for posting this fix. After 2 years of this annoying message I tried this procedure and it worked! The nearest Volvo dealer is 4 hours away so the car is serviced locally in our very small and rural town. Our auto shop doesn't have the gadget for resetting, so knowing how to do it myself is fantastic!
Linda
Linda
Hi Linda, welcome to MVS.
Glad that the site has been helpful to you so far.
PatrickHenry
- Has thanked: 3 times
On our 2005 Volvo S60, the following worked:
To reset the "time for regular service" message, the steps are:
- turn the ignition key to position I
- then press and hold the odometer reset button
- turn the key to position II
- hold the odometer reset button until the triangle flashes
- quickly release the reset button and then turn the key to the off position.
Note that the odometer was **already at zero** and it worked anyway for me.
Thanks for your help!
DeMan wrote: . . . So if they are 0.0 and 0.0, then drive around the block and put .4 miles on T1 and you will be able to detect the change from T1 to T2 mileage. (0.4 to 0.0)
* So the steps are:
- turn the ignition key to position 1
- then press and hold the tripometer reset button
- don't wait, turn the key to position 2.
- hold the button untill the service light flashes 2 times, or the trip mileage changes from 1 to 2 or 2 to1, or the triangle flashes.
djmutters69
- Year and Model:
DeMan.....
That was great advise I tried several other settings without joy however when I tried following your instructions it worked straight away so just wanted to say a big THANK YOU
Djmutters69
* So the steps are:
Djmutters69
* So the steps are:
FYI...this worked for a 2008 S60 also. Thanks. That service message was driving me crazy.To reset the "time for regular service" message, the steps are:
- 2910 Views
Last post by Masscomguru
- 3550 Views
Last post by MadeInJapan
- 38283 Views
Last post by WVI
- 1554 Views
Last post by Blacklab467
- 995 Views
Last post by ggleavitt
