Going on hiatus, mega sale thread! :)
beewerks
Year and Model: '98 V70 AWD LPT
Post by beewerks »
I do still have a few left I think. I'll send you a PM.
beewerks
Post by beewerks »
Can't edit original post to update what all has been sold or things I have added, so here is a current list. I can get you pics of anything you want.
Front strut dust boot covers. Brand new and never installed. $6 each.
Front strut bump stops. Brand new and never installed. $15 each.
MAF sensor for 850 and x70 with mounting tube. Used, but worked great when removed. $50
Custom turbo-back exhaust from 1997 850 R sedan. Should work on S70's, not sure if the wagons are longer or not. Turbo to Cat is 3 inch pipe, with O2 sensor in front of and behind Cat. The Cat rattles around a bit. The muffler is a 2.5 inch Magnaflow straight-thru with polished tip. The tip has a dent on the top of it, but it's not too noticeable when installed. Includes clamps for the flanges. I'd prefer to sell locally, since shipping would be a royal pain. More pictures available on request. $350.
Pair of P2 sidemarkers off of an S80. Comes with bulbs and good length of wire. $28
Various foglight related relays and dash switches for adding foglights to your car. $5 per switch, $3 per J relay, $12 per main light control relay or 213 relay.
Defrost, TRACS, and Sunroof switches from '97 850R. $4 each
Various climate control knobs and blanking plates from 850's. $1 each
3 non-turbo intake manifolds and 1 non-turbo large 65mm throttle body with sensor. I accumulated all of these while on my search for the correct number of vacuum ports. One is from a '94 850 and has a vacuum variable adjustment thing on it. The middle one in the pic is from a '98 V70, and the top one is from I believe a '96 850 and currently has a throttle body mounted on it. I can sell the throttle body separately if you like or pair it up with a different manifold. Great for doing the Snabb N/A throttle body swap on your turbo car! N/A throttle body is $45, your choice manifold is $60.
Non-turbo 65mm throttle body with or without brand new Snabb silicone throttle body hose and it's 2 T-bolt hose clamps. The throttle body has the elusive 960 flat throttle plate. This was cleaned and then never installed in my car, it looks awesome! Throttle body and 960 plate $70, Snabb TB hose, $50.
Zimmerman rotors for a '98 V70 AWD. Will fit others. These are cross drilled and are brand new. One of the front rotor's hat's has been painted black with high temp paint. Front pair $120 Rear pair $85
Key fob for 850 models. In decent shape, writing still shows a bit on buttons and no cracks in casing. $20
Key fob from an '01 XC70, works for early P2 cars. Part # 9459368 Decent condition and no cracks. $18
