oil filter woes
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
Re: oil filter woes
Crankcase vent??? How about the PCV system??? Have you ever serviced or replaced it?
- hanzbe420
- Year and Model: 2006 s60 2.5T
I just replaced it! lol. Its gotta be coming from that hose that goes to the turbo to that half round thing underneath the fresh air hose. Anyways i bought a wrench for 3 bucks a fram 1 and it was like a jaw type. so i broke it trying to get the stp off, i said forget this and jammed a Phillips head into it and turned it until it came off and the replacement Bosch filter fit right on in 2 seconds. I new the 1st ones threads had to be messed up!
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 19 times
The oil filter only needs to be a little more than hand-tight. I use a rag or one of the bottle opener rubber grips to get it on about as tight as I can by hand.
'98 S70 T5
2016 Chevy Cruze Premier
- hanzbe420
i no. my dad only did it hand tight he said. anyways the replacement fit. Got any ideas about were that smoke was coming from in the rear of the engine? it doesn't come out on regular only when i sea-foamed it. I think its that hose under the turbo hose.
jblackburn
I think it's the gasket between the turbo and exhaust downpipe to the catalytic converter. Mine did the same thing when I seafoamed it, and someone else mentioned it too. I wouldn't worry about it.
'98 S70 T5
- hanzbe420
well there's oil leaking so i just wanna no whats leaking so i can see how much its gonna be. ill get pics today when it warms up of the hose i think it is, if i can get the camera in there.
Just a cool subject they did a test on a bunch of oil filters and found that Walmart supertech filters were one of the best , up there with k&n and I think it was fram that was the worst ill see if I can find the site
