Volvo V70 XC wont start, no compression cylinder 1,3,5.
greyfoxisa
Year and Model: 1999 Volvo V70 XC
Post by greyfoxisa »
Alright i confirmed the timing was good so i bit the bullet and removed the timing cover and camshafts in a last ditch hope that i was just getting the timing wrong. I ran the compression test on each cylinder with it at the bottom that way if the valves are all shut which they should be, you would get some compression. Again cylinders 2 and 4 had compression, 1,3,5 had none. So i will be taking the head off AGAIN on Monday to see what the issue with it is.
Another question, i replaced the head gasket right before this with a felpro and used copper petmatex gasket spray on it, should it be safe to re-use this? Also i installed new head bolts, my assumption that even though they are new, i should replace them AGAIN to be on the safe side correct?
Billc1015
Year and Model: 1994 855 turbo
Post by Billc1015 »
You never want to re-use a headgasket. They are a 1 time use only.
regent
Year and Model: 2015 XC60 T5
Has thanked: 2 times
Been thanked: 12 times
Post by regent »
Would not re- use the head bolts, either - they've already been stretched. Use new; this rule applies to ALL fasteners that are subject to angle-torqueing!
2015 BMW 335i
2015 XC60 T5 Premier Plus
2002 S60 2.4 n/a - retired :(
1987 340 DL - retired :(
greyfoxisa
Alright, now quick question when i did the timing before i used the timing marks on the camshaft gears, can i just use the ends of the camshafts with the slots to put them in at TDC or do i have to use the timing marks?
greyfoxisa
Oh and i am assuming i will need to replace some valves, i am just going to pull some good ones from a junker, what other models are compatible for the valves for this car, again it is a 99 volvo v70 xc AWD turbo 2.4l
Faust
Year and Model: xc70 2008
Has thanked: 31 times
Been thanked: 10 times
Post by Faust »
Not a Volvo expert by any means,but I have been around a few engines. First "no" compression in 3 cylinders diminishes my inclination to suspect a bad gasket. It is just "too bad". I am also not giving much thought to holes in three pistons. My first thought would be valve timing, this should be easy enough to determine without disassembly. As to the intake valves, I am wondering if you could hear compression leakage through the intake. The next thought is bent valves. Is it possible to measure valve spring height on the Volvo? Using the two known good cylinders as "controls" it should be possible to locate "short" valves. If they are bent enough to produce "no compression" they should appear "short".
If the engine is being turned by hand, I would expect some leakage of compression. Perhaps enough to give readings of no compression.
2004 V70
1964 Plymouth Convert (small block)
1967 Dodge Coronet (big block)
greyfoxisa
Alright i opened her up today, head bolts where not that tight, i think what happened when it was having the random misfires it cause the timing belt to jump because all the valves hit the pistons, i think that is what caused the head bolts to stretch a little more which is why they were not as tight as they should be. I am thinking i should just pull a whole cylinder head from a junked one just to be on the safe side because i am worried the shafts for the valves might be messed up from them getting hit. Also do i need to worry about the pistons? There are indentations where the valves hit.
Would a 2000 S70 2.4L cylinder head fit it?
Billc1015
Post by Billc1015 »
When I worked at the dealer I had an S80 T6 that the belt jumped and bent all the valves. I was able to just replace the valves. The pistons were fine.
I am here: http://maps.google.com/maps?ll=40.248367,-75.242940
greyfoxisa
Thanks bill, i did some searching around and it seems that the pistons pretty much never get damaged enough to need repairs from a valve hitting them. Question remains though should i replace the cylinder head? or just the valves? i am going to pull the valves out tonight with my spring compressor and see what the condition of the seats are.
Billc1015
Post by Billc1015 »
Make sure you check the valve guides. I have seen those crack from valve hits before. I can't remember if it was on a Volvo engine or not.
I am here: http://maps.google.com/maps?ll=40.284701,-75.287574
