1995 850 t5-R
Forum rules
Please create one topic per Volvo you own. Then simply post to that topic when you maintain or repair your Volvo. You'll have a nice record of what you did, when, and how much it cost. Only you can post in your topic.
polskamafia mjl
- Has thanked: 19 times
- Been thanked: 21 times
Re: 1995 850 t5-R
September 23, 2013 - 211,100mi
Replaced spoiler brake light with new brake light assembly from Volvo dealer
polskamafia mjl
October 10, 2013 - 211,8XXmi
Replaced front brake hoses with temporary units from Advanced Auto Parts
Bled brakes at all 4 corners with ATE Super Blue Racing Brake Fluid (which is apparently illegal in the U.S. as of August 2013 -> http://hooniverse.com/2013/08/16/brakin ... tribution/).
Replaced missing upper intake manifold bolt with new bolt from IPD.
Replaced broken washer fluid reservoir cap with new one from IPD.
polskamafia mjl
October 9, 2013 - 211,959mi
Passed inspection (emissions & inspection) at Monro Muffler/Brake, N Atherton, State College
polskamafia mjl
October 14, 2013 - 212,006mi
Replaced gear shift lever light
Replaced window switch pack with new used unit
Adjusted slack in e-brake cable
polskamafia mjl
October 23, 2013 - 112,344mi
Wiper arms replaced, metal stops ground down
New wipers (Bosch Evolution)
Oil Change @ VIOC
- Valvoline Semi Synthetic Blend 5W30
- Mann Filter
Drain and Fill with Mobil 1 Synthetic ATF (4 qts)
Oil Change @ VIOC
- Mann Filter
polskamafia mjl
November 5, 2013 - 113,074mi
Replaced Front O2 Sensor with Bosch 15097 Oxygen Sensor
polskamafia mjl
November 12, 2013 - 113,xxxmi
Exhaust leak behind cat repaired at Midas in State College.
polskamafia mjl
February 2, 2014 - 216292mi
Rotated Tires (Front to Back)
polskamafia mjl
February 20, 2014 - 216,652mi
Passenger side front tire replaced with General G-Max AS-03 (205/50R-16) at Midas in State College.
Ventus V4's no longer in production.
polskamafia mjl
March 10, 2014 - 217,427mi
Oil change @ VIOC
- Valvoline MaxLife (Semi Synthetic) 5W30
- Mann Filter
Broken EVAP hose near fuel filter noted
Oil change @ VIOC
- Mann Filter
