volvo 850 1996 code p1310-p0304
paco0021
Year and Model: 850 1996
Re: volvo 850 1996 code p1310-p0304
Post by paco0021 »
volvo at gap 28
paco0021
Post by paco0021 »
I swapped the plugs and nothing happen still code p1310-p0304
Has thanked: 292 times
Been thanked: 765 times
Post by erikv11 »
I would probably next swap the #4 injector with say #1, for a similar test.
Not very difficult but you want to make sure you don't lose or damage any of the rubber seals or the o-rings. I think the pinned writeup for the PCV includes instructions on removing injectors if you want to see some pictures and what everything looks like, before you remove them.
Do you think there is fuel getting in there? Is the plug wet and smelly with fuel or dry?
What about if you unplug the injector and drive around, is it the same or worse?
You are likely going to want a compression test if it isn't a bad injector. Hopefully it didn't burn a valve.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
chrisjm91
Year and Model: 95 Volvo 850T5
Post by chrisjm91 »
I know this is almost 3 years after the most recent post; but I have the same exact issue. Long start, heavy misfire on start up for a dew seconds. Just as of an hour ago its misfiring heavily for a few seconds on acceleration from a dead stop. I have a live data scanner and its telling me my long-term fuel trim is at 25%......... ( the reason im delving into these posts)
My plugs, wires, distributer cap and rotor button were changed a few years ago but the car has barely driven since then. But im going to inspect everything you guys mentioned: spatk plugs and theyre status, wires, the distributor cap and button. Anything else?
misha
Year and Model: '97 850 2.5 20v
Has thanked: 152 times
Been thanked: 402 times
Post by misha »
What codes you have?LTFT at 25% is saying that engine is running rich.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
chrisjm91
Post by chrisjm91 »
Just pulled the plugs wires out as gently as I could. And they're pretty dry. The cars still hot but im going to see if the plugs are willing to come out....
240gator
Year and Model: 1996 850
Post by 240gator »
chrisjm91 wrote:Just pulled the plugs wires out as gently as I could. And they're pretty dry. The cars still hot but im going to see if the plugs are willing to come out....
Did you ever resolve this issue? Just started getting these codes as well.
1985 240 Turbo 310K | 1995 Yellow T5-R 236K | 1996 850 Turbo 225K | 2005 S40 2.4i 139K | 2005 XC90 2.5T 179K | 2007 S40 T5 141K
Tetraguru
Year and Model: 1996 850 T5
Post by Tetraguru »
Just got myself a tune up 5 days ago (Plugs, wires, distributor, rotors and the main engine relay) - and last night when pulling into my driveway, i had to do a quick reverse and adjust to make the turn (I overshot the turn by 2 feet) . When i shifted from reverse back to drive - that big fat shift up arrow popped on the dash (had not moved the car yet) - when i did - there was practically no power but the engine wasn't racing - just weak. I plug in my machine after parking - and I got 4 codes 0P300 / P0301 / P0303 / and P1310.
