98 V70 X/C AWD Bad rear differential
jimmy57
- Been thanked: 320 times
If the diff is bad and you want to remove it then you have to dismantle the rear halfshafts. The outer CV joint housing, which is integral with the splined end that passes through the hub, has to be retained in place as it keeps the wheel bearing together on that car.
- 732 Views
Last post by LuthierIan
- 1953 Views
Last post by Bamseclub
