Pulled the FPR last night and cracked it open. Solder looked pretty good, but ordered up a new one anyway as the caps might be bad. If that is not the issue it will be one someday, so better to have a spare.
Used about a can of carb cleaner around all the lines and found nothing. Still think I have a small leak somewhere.
Recleaned the IAC just in case. Pulled the ECU and cleaned the pins.
Ran great this morning (very cold weather), but my issue is intermittent enough that one 15 min drive does not tell me too much. Need to get through a couple drive cycles.
'98 T5M Idle and Power Issues
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 19 times
If a vacuum leak was the problem, it would be consistent.Cleaned the MAF last night. Definitely dirty, had some black buildup on the leading edge of the sensor. Ran really well after the cleaning and idle was rock solid after the computer relearned. Continued to run strong today without any issues. I suspect that the dirty MAF was the main culprit.
I'm inclined to think that the mass airflow sensor may be giving flaky readings at times.
'98 S70 T5
2016 Chevy Cruze Premier
echase76
- Year and Model: 1998 v70 T5m
Thanks for the thoughts. This is definitely not a consistent issue.
I have a used but working MAF paid for, but the seller is being VERY slow delivering. FPR will be here Wednesday.
1998 V70 T5m Silver/Charcoal - 150K
echase76
Ok folks it looks like I can close the book on my issues. Turned out the be the MAF going south (jBlackburn you were right!). Didn't seem like the classic MAF symptoms, but that is what did the trick after trying everything else. For the past week I have had no issues and runs strong.
Thanks for all the help and ideas!
