It's been awhile since the last post on my thread. I wanted to close the loop on this and share my lesson learned.
After I replaced both front half shafts from AutoZone, I suffered front wobble for over a year. After scratching my head for a long time, I picked up used genuine Volvo half shafts. Using those, the wobble is gone.
V70 seems to be sensitive to the manufacturing tolerance of half shaft. Just wanted to share this info with others.
Wobble when accelerating
- GBS
- Year and Model: XC70 2003, V70 2002
Hey Tony I second your findings. After trying an aftermarket axle on my V70 I'm now convinced rebuilding the original CV joint is a much better way to go. I only did pass side and seen driver being more difficult, replacing boots and re-greasing passenger side was easy and save a few bucks over replacing full axle.
Tonyx
- Year and Model: 2001 XC70
- Has thanked: 3 times
- Been thanked: 8 times
I actually found the pass side to be easier. It's longer and there is bearing bracket in the middle but it sled out of transmission without issue. You need to undo the tie rod, stabilizer bar end link and the brake caliper to allow you to rotate the knuckle on its lower mounting bolt(remove the top bolt and loosen the bottom bolt). With this you work the half shaft out. And agree with you to stay with Volvo half shafts.
2003 XC70 230K and counting..,
- 16 Replies
- 3870 Views
Last post by Clemens
- 11 Replies
- 1558 Views
Last post by MoVolvos
- 18 Replies
- 3893 Views
Last post by soulvoid1990
- 827 Views
Last post by iruleyounow
- 761 Views
Last post by vtl
