Update to my tranny dillemma. 95 850t auto.
Has thanked: 292 times
Been thanked: 765 times
Re: Update to my tranny dillemma. 95 850t auto.
Post by erikv11 »
Southbay850 wrote:It wont idle in drive after warm up. When I drive it for a couple minutes the engine will stall when slowing down or making a full stop.It seems like the tranny puts the engine under too much of a load and does not go into the normal idle you would have when you slow to a stop and are still in drive with foot on brake. It grabs gears fine except reverse. Someone else mentioned it could be soleniods.
This must be due to the trans heating up, not the engine heating up, but you could check. Warm the car up well in the driveway before you drive, it, does it stall right away or only after the trans also gets warmed up?
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
Southbay850
Year and Model: 1995 854T
Post by Southbay850 »
It only does it after warming up
98T5
Year and Model: V70T5,98' / 940,93'
Post by 98T5 »
Could it be starving for gas? Does it pick back up after the stall?
98’ S70 T5 Turbo Manual - Midnight
01' S60 T5 Turbo- Brandy
98' V70 T5 Turbo - Swifty
93’ 244 n/a - Mr.Chill
91' 940 SE Turbo - Mojo SOLD
83' 242 DL - Bluto SOLD
93' 940 Wagon - Django - SOLD
:mrgreen: 8) :mrgreen:
mercuric
Year and Model: 1997 850 T5
Post by mercuric »
Personally, I'd check the hydraulic pressure of the transmission as the next step. It sounds suspiciously like the pressure may not be within spec -- causing things to fail to engage/disengage when necessary.
I could be totally off base, but it seems a logical test based on what's happening. I'm no tranny expert, so just my 2¢ of what I'd be doing.
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 19 times
Post by jblackburn »
mercuric wrote:Personally, I'd check the hydraulic pressure of the transmission as the next step. It sounds suspiciously like the pressure may not be within spec -- causing things to fail to engage/disengage when necessary.
Agreed. I'm wondering if the filter screen inside the transmission (not really user-serviceable) is partially clogged and can't provide proper pressure when the fluid thins out when hot.
Or if a line pressure solenoid is to blame.
'98 S70 T5
2016 Chevy Cruze Premier
Southbay850
I saw these filters being sold on ebay. Whats the point of even having one if you cant access it to change when needed.
