1998 volvo v70 stalling, 5 codes
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 20 times
Post by jblackburn »
Jonc123 wrote:
jblackburn wrote:
Jonc123 wrote:another question....If the cam sensor is bad then the car wont start at all right?
Depends how it failed. It may fail only when hot...in which case, the car would start and then die out when it loses a reading from the sensor.
It doesn't stall out when hot, Just when i drive down the road and come to my first stop. However I just disconnected the mass airflow sensor and the car did not stall out. It ran a little rough but didn't stall. So im going to go ahead and replace the MAF sensor. Im just not sure where im getting the cam code from so I inspected the connection and cleaned it out....
Well, that's something.
Make sure that the cam position and crank position wires (2 big fat insulated ones coming from the sensors) are as far away from each other as possible - zip-tie them if you can. They'll cause interference with each other and codes and/or bad running if they get too close to each other.
'98 S70 T5
2016 Chevy Cruze Premier
precopster
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
It's more a problem that the large coil lead causes interference due to it's high voltage and resultant high EMF so all wires should be away from the coil lead. The factory placed a plastic clip on the torque mount to hold the crank sensor lead but most of them have fallen off
Jonc123
Year and Model: 98 v70, 87 240,
Post by Jonc123 »
sensors) are as far away from each other as possible - zip-tie them if you can. They'll cause interference with each other and codes and/or bad running if they get too close to each other.[/quote]
Ok i replaced the MAF and It works good now....dosent stall anymore. The wire between the cam and crank were touching so i separated them with the zip ties. I also cleaned the Throttle body, plugs and wires and found that the evap codes were in fact coming from a separated line as abscate suggested. Cleared the code and hoping nothing comes back. Thanks everyone for the help!!
Has thanked: 1613 times
Been thanked: 4075 times
Nice. Another Volvo conquering the entropic slide
