Starter Not Disengage 1997 850 T5 RESOLVED, wiring wrong
drzaeis
Year and Model: 1997
Has thanked: 3 times
Post by drzaeis »
cn90 wrote:To rule out tumbler issue...
- Remove the Ignition Switch (LEFT of steering column).
- Use a flat blade screwdriver to crank the car and then bring the screwdriver back to position II (run).
* If the starter stops running ---> tumbler issue (I have a spare one lying around)
* If the starter continues to run ---> problem with starter solenoid (whoever rebuilt it probably did not lube the solenoid properly) and/or wiring.
already did this..starter still runs...
drzaeis
Post by drzaeis »
Ozark Lee wrote:Elaborate on how you have the starter wired.
The large main terminal should have both the battery and the alternator wires, together on the same large terminal. The green/red wire then goes to the small lug on the solenoid.
Lee,
here is a pic of the wiring, after I start the car if I pull the little green wire the starter still runs...
here is the pic of the wiring..maybe I should try another starter???
Has thanked: 1611 times
Been thanked: 4075 times
I think that is a firm diagnosis of a bad starter solenoid.
jimmy57
Has thanked: 5 times
Been thanked: 322 times
Post by jimmy57 »
The cable you have on inboard stud should not be there (brown cable). Only the braided little piece of wire that goes into motor case of starter. Your alternator is running the starter motor the way it is wired according to the picture.
The battery is the red one and when you turn the key the green wire turns on the solenoid and starter works as it should. Then alternator starts charging and runs the starter motor with its output.
Both of those cable will fit only the outboard longer stud but I think the brown one is turned a half turn as shown.
I'm going to remember this. That is a neat trick to pull on a buddy. Well, maybe not a buddy.
Nice catch Jimmy...
+10,000
drzaeis
Post by drzaeis »
jimmy57 wrote:The cable you have on inboard stud should not be there (brown cable). Only the braided little piece of wire that goes into motor case of starter. Your alternator is running the starter motor the way it is wired according to the picture.
so I should move the inboard cable, (brown as you say but it looks black to me), to where? both should be on the outer stud? then the inner stud only has the braided wire that goes to the motor case??
thank you thank you!!! I think we're getting close...I hope!
Year and Model: 2004 V70 2.5T
Been thanked: 504 times
Post by cn90 »
Interesting re brown wire...
But according to the thread below, that extra wire is feeding the aux fan:
https://www.matthewsvolvosite.com/forums ... =1&t=36780
Below is the schematic of the wire that "JPC412" and "BEJinFbk" talked about in the thread above:
Post by cn90 »
O.P.
I still think you should do the screwdriver trick I mentioned above to r/o the tumbler.
jimmy57
Post by jimmy57 »
Yes, the short stud is only for the braided wire that comes out of starter motor case right by it. The other large cable, whatever color, is supposed to be on the stud with the red cable already there. The starter solenoid does two things: It pulls the solenoid armature (aka "plunger") in so it pulls the pinion into flywheel teeth and the armature depresses a button that pushes a copper disc against the heads of the two studs to connect them. This connection sends battery voltage to the inboard stud for the starter motor lead to run the motor and nothing else connects there.
drzaeis
Post by drzaeis »
cn90 wrote:Interesting re brown wire...
Got it. Both red wires are supposed to be on the outer terminal...one is from the battery the other goes to the alternator.
THANKS EVERYONE!!!!
