96 850 Car stalls after 5 minutes - RESOLVED, bad MAF
devangelisti
- Year and Model: 850 1996
- Has thanked: 1507 times
- Been thanked: 3824 times
okay - I think I would move to the no-start condition and determine if it is spark or fuel problem. Check fuel pressure at the rail first - or listen for the fuel pump turning on?
devangelisti
Here is what I did today.... I decided to run the car without the MAF connected...it started and ran fine for over 20min and did not shut off. I shut it off and started it again.. it ran for another 20 min with no problems.. then while it was running I connected the MAF harness..it shut right off!!
Could it be a bad MAF and the ECU senses a problem and shuts the engine...
Yep, try new MAF, adapt and then report back
devangelisti
YUP.. New MAF did the trick..what a strange problem...
- Has thanked: 293 times
- Been thanked: 765 times
This thread describes is standard symptoms and diagnosis method for a bad MAF, everything makes sense. Nice job on the repair. If the new MAF is not a Bosch then be prepared for more funny business down the road, the non-Bosch ones rarely work properly in an 850.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6
153k
'06 S60 R, 197k
'99 Camry V6
- 2842 Views
Last post by itsmekirby
- 814 Views
Last post by Bero
