1997 850R Compression test results
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
If it smokes constantly, your PCV desperately needs cleaning.
If after just idling/sitting for long periods, you need stem seals.
Compression looks OK.
'98 S70 T5
2016 Chevy Cruze Premier
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
I RUN Mobile 1 because it's hard to find any other 10W-40 in any other full syntheitcs. I have had good results and a very good report from Blackstone Labs.
Double check for a loose vacuum elbow. One may have come off.
mikealder
- Year and Model: V70 2000
- Been thanked: 13 times
When you cleared out the PCV did you check the lower port on the front face of the engine where the PCV tank connects was clear, best way is to connect a length of 5/8" rubber hose to the port and try to blow through it, if you hear bubbles from the sump then it is clear, if you can't blow through it the port is blocked. I had to pull the sump to clear it out as it was packed with carbon - Mike
mattman
- Year and Model: '97 850R TurboWagon
Hey folks, just finished leak-down test,
9%-8%-10%-9%-21%
All within "good" guidelines...
PCV was done pretty methodically last Feb., although I don't remember blowing into the motor.
Good tip tho...
Great write-up on motor oil too, think I'll do a quick switch back to dino oil, and see what happens.
9%-8%-10%-9%-21%
Good tip tho...
- rspi
Contact rspi..
I would go 1 step thicker than to go back to dyno. Yuk!
jblackburn
Not really. Synthetic should be fine, especially in high temps.mattman wrote:Will do.
Opening filler cap while car is running launches oil out.
No, I didn't over-fill...
I think the Synth is just too viscose in 100 degree weather with engine running.
Put a latex glove on top of the filler cap hole. Does it inflate?
'98 S70 T5
jblackburn
Oh, that's good news for the PCV theory then.mattman wrote:No, it almost sucked it in.
That's fine, cross that one and bad rings off the list.
Yep, 10W-40 step-up sounds good...but I would stick with synthetic, especially in hot temps.
'98 S70 T5
- 1790 Views
Last post by rspi
- 4577 Views
Last post by erikv11
- 1373 Views
Last post by hamiltoncj76
- 913 Views
Last post by Christopherjz
- 1071 Views
Last post by matthew1
