1998 v40 t4 Loss of power, then total stall [RESOLVED]
1996 - 2004 S40
1996 - 2004 V40
def420
Year and Model: v40 t4 1998
Re: 1998 v40 t4 Loss of power, then total stall .
Post by def420 »
:-] Just ordered the walbro pump upgrade, and a brand new fuel pressure regulator (what a pricetag for this little fellow)
Hopefully this will make my Volvo drivable once again. As of now, its a quite expensive peace of metal, just standing there.
def420
Post by def420 »
Update: Got the walbro fuelpump (should have checked up better before buying), and the FPR. Took out older (still brand new) fuelpump, and load and behold, the tubing + pump was totally dead. The tube had split lenghtwise all the way :-[ Didnt check this first, as the pump was brand new. Got the Walbro 342 pump installed (should have been the 340, as it has the large diameter inlet), and all worked fine, got pressure up to max again. The FPR on the other hand, was for another car (they send me the wrong one) After some fiddling, resulting in me sticking a piece of wire into the valve, just to get the fuel flowing, all was back to normal - well almost that is.
Thnx a million for the help and guidance here, truly amazing :-]
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2660 times
Been thanked: 1248 times
Post by matthew1 »
Thanks for the resolution. Good to hear you solved it.
Also -> Amazon link
