99 v70xc rough running ,code for cyl. 4 misfire
Year and Model: Many Volvos
Been thanked: 76 times
Post by Ozark Lee »
Pauloil wrote:got the head off and plan to take it to machine shop in town. where is the directions how to reset the VVT, and set the timing? have VVT on exhaust cam
Did you remove the hub on the front side of the exhaust cam when you removed the head?
If so, you will need a camshaft adjustment too to get things set back and I can post the full procedure for you.
If you left the hub on then you can simply re-align the marks (with the timing belt on) and set the preload by simply rotating the engine 90 degrees clockwise and then back to the marks counterclockwise. That set the preload and you just remove the timing belt from the camshaft sprockets and adjust the outer sprocket on the exhaust hub to line up with the timing marks as you re-install the timing belt.
