Following up on this issue with the oil leak - I brought it into a wonderful little one-man shop in the Denver area. The mechanic ran some tests and there was excessive crankcase pressure. Apparently the oil trap I put on (that was supposed to be an OEM part) was not good and has some sort of block in there so no gasses were being drawn out. The oil leak was being forced up around the bottom of the oil dipstick tube (where it enters the block). I still had the oil trap I took off and we cleaned it up and put that one back on and the engine is as dry as can be.
Regarding this "OEM" oil trap, it simply has a black and white sticker on the part saying it is OEM, and has the part number embossed on the top of the oil trap - but there is no "Volvo" also embossed with raised letters on the top. The one I had taken off, had Volvo actually stamped on the part. I'm wondering if this part is actually OEM, or if it is a cheap junk counterfeit part. Does anyone know how new Volvo oil traps come nowadays? Do they still have Volvo embossed on the top?
1993 240 Oil Leak Question
mtd240
- Year and Model: 2007 XC70
- Has thanked: 23 times
- Been thanked: 7 times
If it doesn't have "Volvo" written on it in some way, shape, or form, it's not Genuine Volvo (with the exception of fuses, some hoses, maybe other little stuff).
There are "OEM" parts, which are the original manufacturers of the parts, selling them to you directly rather than through Volvo (Bosch, Lemforder, Sachs, Boge, Continental, SKF, INA, etc etc). These are usually identical to Genuine Volvo parts.
Then, there are "Meets OEM specs", and other aftermarket stuff (URO, ProParts Sweden, Scantech, GMB, etc). There is actually a company called "OEM" that sells aftermarket parts. China will do anything to get their garbage under your hood
You probably bought an aftermarket box - usually they are made by Ramac. The breather box has two halves. The OE Volvo box is "plastic welded" together, basically forming a uniform piece, whereas the aftermarket (Ramac) glues the halves together. The aftermarket box is known to fail prematurely at the glued joint (read up on turbobricks and brickboard). It is better to buy the OE part, if you buy it; but usually cleaning the old box is feasible (much cheaper too).
Run synthetic oil, and you probably won't ever need to clean it again.
2007 XC70, white/oak, 175k miles
2008 XC70 3.2L, 115k miles
2016 XC60, osmium grey / off-black, 95k miles
Gone:
1990 240 DL Wagon, M47, lots of goodies. 372,000 miles
1978 242, lots and lots of work to get a reliable daily
1998 V70 XC, Almost done replacing everything, then I sold it
1996 850 NA, victim of sporadic tree falling. Protected the wife. RIP Volvo
Gone:
SmokinJazz
- Year and Model: 240 1993
Thanks for the info. I thought I was buying an OEM part. I'm not happy with them selling crap and passing it off as OEM. Their site (new-part.com) looks legit, but obviously they are not. I was reading through their return policy and it states on there regarding the parts that are faulty have to be installed by a certified mechanic and you have to have a receipt proving they installed it - then they will take the part for you and return it to the manufacturer for the final verdict before they return any money. But how many among us are certified mechanics? Its a scam and they really cover their butts well. I would have saved money in the long run if I just bought all my parts from the dealer only. Real Volvo parts are made much better. In the past, I got some cheap hoses that have split on me, but shipping would cost as much as the refund for them.
mtd240
Buy from FCP Euro. They have a lifetime warranty on everything, even if you install it yourself. Decent prices, too.
Gone:
Gone:
- 932 Views
Last post by mtd240
- 1528 Views
Last post by 93ForMe
- 1290 Views
Last post by ducttapeandzipties
- 1419 Views
Last post by t3yf5g
- 1024 Views
Last post by volvolugnut
