1997 850 N/A - Engine noise - Camshaft squeal?
helohero
Year and Model: 1997 850 Non-turbo
Post by helohero »
Ozark Lee wrote:
helohero wrote:Rod bearing?
Sure sounds like it. If you get a socket wrench on the harmonic balancer nut and then rock the engine back and forth by hand you can often feel it. If it is in the bottom of the engine then a used engine is the only real alternative if you want to keep the car.
Thanks for your insight. It is definitely appreciated. Now time to do some thinking on what I want to do.
Has thanked: 311 times
Been thanked: 817 times
Post by erikv11 »
I have never tried comparing to pictures when the head is off, but I have always seen the mark. And always rotated the crank after the head was off for cleaning purposes etc., so I had to find it. But yeah, timing should be fine if it never moved.
mtd240
Year and Model: 2007 XC70
Has thanked: 23 times
Been thanked: 7 times
Post by mtd240 »
Sounds very much like yours..
2007 XC70, white/oak, 175k miles
2008 XC70 3.2L, 115k miles
2016 XC60, osmium grey / off-black, 95k miles
Gone:
1990 240 DL Wagon, M47, lots of goodies. 372,000 miles
1978 242, lots and lots of work to get a reliable daily
1998 V70 XC, Almost done replacing everything, then I sold it :lol:
1996 850 NA, victim of sporadic tree falling. Protected the wife. RIP Volvo
helohero
Post by helohero »
I agree, sounds similar.
I don't think this 850 is worth saving. I'll probably sell a few parts off of it and then scrap it.
Year and Model: Many Volvos
Been thanked: 76 times
Post by Ozark Lee »
What bothers me about this is that the noise cropped up so soon after the top end work. I suppose it is possible that the l got hot enough to do damage to the lower half when the car originally overheated but I would think that the present symptoms would have presented themselves fairly immediately after the head went back on and the car was re-started. Usually when a problem arises just after a related repair then the repair itself is where I start looking.
If a valve is sticking and getting slapped by a piston then it should show up in a compression test. Other than the God awful noise, the engine seems to run pretty smooth which would indicate good compression. That is what makes this such a mystery.
mtd240
Post by mtd240 »
helohero wrote:I agree, sounds similar.
Pull the oil drain plug and see what comes out.
Gone:
Post by erikv11 »
I would also check the half moon pieces on the ends of the cams especially behind the CPS, make sure they are tight. Longshot but it did just get top end work, and if it's going to the scrapper otherwise ...
helohero
Post by helohero »
I've been busy this weekend, I'll drain the oil tomorrow and see if anything comes out with the oil.
helohero
Post by helohero »
erikv11 wrote:I would also check the half moon pieces on the ends of the cams especially behind the CPS, make sure they are tight. Longshot but it did just get top end work, and if it's going to the scrapper otherwise ...
Are you talking about the metal pieces that are attached to the camshafts under the camshaft position sensor and distributor cap?
Post by erikv11 »
Yes. Maybe only the CPS one could slap around. And granted, that would not explain why the engine was hard to turn over ...
