1997 850 NA - Issues getting car out of 'P'
esl_97_850_T5
Year and Model: 1998 S70 GLT
Has thanked: 18 times
Been thanked: 27 times
Re: 1997 850 NA - Issues getting car out of 'P'
Post by esl_97_850_T5 »
The ABS will light up when the brake pedal switch is bad.
If you read the ABS codes with an ELM327, the ABS brake pedal switch DTC will manifest as ECU 01 raw hex DTC 65.
With Vol-FCR, I believe it is ABS-142.
Reading the ABS codes and/or examining the brake lights might help to totally rule out the brake pedal switch as a possibility.
If you have ECU 01 DTC 65 (ie, ABS-142), then clear it. If it then returns, it is likely you have a failing or failed brake pedal switch.
1998 Volvo S70 GLT - 205.5K miles - S70 & M44 testbed in 2016-2019; traded 2019-07-15 (for spare time)
1997 Volvo 854 T5 - 147K miles - 850 testbed in 2012-2017; junked 2017-09
Ben850
Been thanked: 7 times
Post by Ben850 »
esl_97_850_T5 wrote:The ABS will light up when the brake pedal switch is bad.
I agree. And then replace the micro switch to get your car out of park without question.
1996 850 Turbo Wagon White.
1994 850 N/A Wagon Black.
1997 850 Sedan Black.
1996 850R Wagon White.
