1999 S70 OBD2 Not Ready, state inspections CT NY CA
Has thanked: 1610 times
Been thanked: 4068 times
And more update. My car passed NYS upstate inspection with the EVAP cycle NOT READY but no codes either pending or showing.
MoVolvos
Has thanked: 312 times
Been thanked: 525 times
Post by MoVolvos »
osman wrote:Tell the inspector that there is a service bulletin to not fail certain Volvos for sensors being unready,It is very common in the 98-99 S/V 70's. Your car is one of them. Let him know those cars can sometimes take months and or never get to the point of "all sensors ready" as long as you have no CEL, tell them to test your emssions. Most times the inspector will look at you strange, but its true, if they refuse to go check the paperwork or check with a superior leave and find some inspection place that looks like some Volvos have probably gone there, so they might be familiar with that, but I have never seen it.
What you are referring to is what use to be called Appendix J. It provides info for the tech on how to bypass the Readiness on their Smog Machines. The shop I've been using, a couple really young guys, have never heard of it but said they would try it and it worked for my 98 S70 T5.
Page 1 Table 2 was the method used to pass my T5.
http://www.rlescalambre.com/APPENDIX_J.htm
http://www.californiasmoginstitute.com/ ... NDIX_J.pdf
_
The EPA (Federal) memo has to be accepted by the state inspector of course. In NY, the DMV website explicitly links to the federal EApA memo but never says that they follow this practice.
I asked my inspector (independent) and he confirmed my 1999 could pass with two circuits not ready.
This is good to know for those pesky "show up every 4 month" codes and if your evap code won't go ready.
I did get the drive cycle protocol and have to say it would be tough to drive that exactly on any roads where I live, unless I drove way out into the country.
MoVolvos
Post by MoVolvos »
abscate wrote:The EPA (Federal) memo has to be accepted by the state inspector of course. In NY, the DMV website explicitly links to the federal EApA memo but never says that they follow this practice.
I reread both links in my earlier post and neither show the 99 Volvo so not sure if they were considered problematic? Wonder if the EPA Federal is different. In CA you can only have one Readiness Monitor not set.
_
Every state sets their own program, so indeed, you have to check with your inspector. The 1999 MY does not show up in the CA Appendix J.
In my case, an older guy knew that in fact NY does follow the EPA protocol. They connect the car to the NY DMV via server but then can over-ride the 'automatic' failure code generated by the NOT READY status, so this state has its act together at least.
adammathewvaughn
Year and Model: 98 V70-XC
Post by adammathewvaughn »
I had the same problem with my readiness monitors a few months ago. The drive cycle listed in this post worked for me.
https://www.matthewsvolvosite.com/forums ... 6234#56234
