2003 S60 Drops out of cruise and goes into limp mode
wouterve
Year and Model: 2004 XC70 / 2018 XC6
Post by wouterve »
maddog2020 wrote:Probably all true, but my car doesn't have an ETM. 2003 (maybe 2002) and later models have an updated Throttle Body. That said I still think it might be my throttle body failing.
You still have an ETM in your car (as that’s just an abbreviation for “Electronic Throttle Module”), but the difference is that yours is not from the problematic batch that affected 2001-2002 model cars. However, despite not being from that problematic series, you might still benefit from cleaning it as alron400 suggested.
The hesitation you describe seems to be happening under high load (accelerating up to the point of a downshift on the highway). I don’t know if you’ve already done so, but it wouldn’t be a bad idea to check your plugs and coils, as any defects in the ignition system tend to first appear under high load situations.
The U0073 code you say you’re finding is pretty generic—before you go and replace all these parts and sensors just by stabbing in the dark, I think it would be worth it to hook your car up to a VIDA/DICE unit to read the Volvo specific codes. That might lead you to a more specific diagnosis about what parts should be replaced and save you money in the end.
Ritsco
Year and Model: S60 AWD 2004
Post by Ritsco »
Not trying to hijack this thread, but I have an S60 AWD and I think I may have almost the same issue. I will be driving along steady state, with no issues. When I get to a hill and the car needs to accelerate (whether on cruise or not) I feel and hear something akin to a sharp clunk, almost transmission like. It does not drop out of cruise or go into limp mode or throw any codes. I can not reproduce anywhere but in that situation. Other than that, trans seems fine, with recent fluid change, new MAF and unfortunately, a new main computer.
Any suggestions/help would be greatly appreciated.
Thank you
