1991 Volvo 740 stalls when hot, replacing parts by chance
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
janefinch
Year and Model: 1991 volvo 740
Re: 1991 Volvo 740 stalls when hot, replacing parts by chanc
Post by janefinch »
Ok I swapped out the two identical relays & with my fingers crossed hoping for a good result.... it stalled. Crap.
Decided to pay my Volvo dealer a visit to see if they had a fuel pump relay {behind ashtray} in stock which they did. $64.00 CAD. Installed the new relay and she run like a top. No stalling. Good for another 1/4 million miles or more.
The old relay was the original dated 1990.
Thanks so much for all your help!
lummert
Year and Model: 760 1988
Been thanked: 26 times
Post by lummert »
Do you know how to solder? I repaired 3 fuel pump relays by re-flowing the solder on the circuit board. All the larger solder connections were cracked. I carefully pried loose the cover. I now carry 2 spare relays in the glove box. One of the relays that I repaired was dated 2005, Which was the year I purchased the car. So, they do occasionally quit working.
The FPR on my 1988 760 is different than on your 740, but the circuits are the same.
1988 Volvo 760 Turbo Wagon
janefinch
Post by janefinch »
Ok thanks. Did not see how the relay come apart. Will have another look later n& see.
Thanks!
Best video ever of the die hard Volvo 740 THE END
http://youtu.be/05W9u5e3LhE
earcher0
Year and Model: 1990 740GL
Post by earcher0 »
Had this exact same problem. After replacing radio suppression relay and fuel pump relay, the problem persisted. It eventually got bad enough that I had a 10 to 1 downtime ratio. (For every twenty minutes of cooling down, I was able to get another 2 minutes of run time.) So I sucked it up and had a shop replace the fuel pump (mine is a Regina with the single pump in the tank) it cost 480 with labor to remove thirteen gallons of rust filled gas water. Hasn't happened since.
93Regina
Year and Model: 93:240/940
Been thanked: 65 times
Post by 93Regina »
earcher0 wrote:Regina...remove thirteen gallons of rust filled gas water
I think my 940 has a plastic/rubber tank...
earcher0
Post by earcher0 »
I think later year volvos have the benefits of a plastic tank.
lummert
Post by lummert »
earcher0 wrote:I think later year volvos have the benefits of a plastic tank.
my 1988 760 Turbo wagon has a plastic tank.
