1998 S70 GLT car stalled MVSOLVED, IAC cleaning
mecheng
Year and Model: 1998 Volvo S70 T5
Has thanked: 15 times
Been thanked: 21 times
Post by mecheng »
If you don't know the service history of the car it is always a good idea to inspect the maintenance items because it is never wasted money: the run will run smoother and use less gas. So check plugs, wires, cap, rotor, fuel filter: these will cause a no start or the car to run rough.
Is there any codes? If not, then check ECT (the Original Volvo part fails after about 130,000km)- usually it throws a code, fuel pump relay solder joints (sounds like you checked this), cam sensor, crank sensor (less likely)
1997 Volvo 850 GLT - 190km
Boost is my drug of choice
Has thanked: 311 times
Been thanked: 817 times
Post by erikv11 »
terris1859 wrote:I went out this morning and the car started,but it seemed to be idling a little rougher than normal, so we decided to unplug maf sensor to see what would happen, car still ran the same after it was unplugged, when it was plugged back in it immediately killed the motor, does this mean the maf sensor is not working?
The car should be off when unplugging and re-plugging the sensor.
If it runs the same without the MAF, then the MAF is not likely the problem.
I sent you a PM.
terris1859
Year and Model: 1998 volvo s70 glt
Post by terris1859 »
We don't have a code scanner but was thinking about getting one. Do the one that cost around $50 or less at auto zone read the codes for these cars? I was going to get one of those but husband says they probably wouldn't work for a volvo, he thinks it probably would take a special one since it is a foreign made car.
jreed
Has thanked: 384 times
Been thanked: 221 times
Post by jreed »
The inexpensive OBDII code readers should work fine on a '98 Volvo (at least, they work fine on my '97, which is also OBDII compliant).
I have seen good deals on OBDII readers at Harbor Freight, especially if you bring one of the ubiquitous 20% or 25% discount coupons:
http://www.harborfreight.com/http-www-h ... -html.html
Has thanked: 1611 times
Been thanked: 4071 times
OBD II is a universal system, you should NOT be spending more than 25-30 for a reader. I bought a bunch of ebay for about 15 bucks because I send three cars to college next year....I keep one in each of the older cars
On edit - left off crucial NOT
mecheng
Post by mecheng »
Yes the generic obd ii reader works perfect on a 98
terris1859
We went to harbor freight and got a code reader and here are the codes I got
p0410- secondary air injection system
p0455-evaporative emission system leak(large leak)
p0500-vehicle speed sensor A
p0174-system too rich bank 1
p0300-random/multiple cylinder misfire detected
p0302- cylinder 2 misfire detected
p0102-mass or volume air flow A circut low
p0304- cylinder 4 misfire detected
Check the evap system for a big hose tear or hole.
Link to come.
One major leak could be responsible for all your codes!
terris1859
So far we have found a hose in the area of the fuel filter that is completely disconnected from I think what you guys are saying is the rollover valve, could this be the problem?
Yep, that's it. You want to look over the whole system and get familiar with it because it is one of the typical maintenance areas of this vintage
