I use an App called Dash Command on my iPhone with a ELM327 WiFi adaptorwestroxvolvo98 wrote:I don't, any recommendations for a decent gauge.
If you have Android you can use a ELM327 adaptor that uses Bluetooth, they are a bit cheaper.
A lot of the Android fanboys use an app called Torque.
I bought the adaptor from ebay and the DashCommand app was $10.
If the temp is sitting at 3 o'clock and you have Volvo parts you are probably okay. I would check cylinder compression to confirm the headgasket is okay.
