WOW! You are right..hold on let me run outside to check on that real fast.RussB wrote:koffinb wrote:
There appears to be no clamp on the upper intercooler outlet hose ???
It's up top near the radiator...
97 855R Just bought it and I love it..except a few issues
Re: 97 855R Just bought it and I love it..except a few issue
1997 855R-Completely Bone Stock..for now
It's there..just a little hard to see in that pictureRussB wrote:koffinb wrote:
j-dawg
- Year and Model: 1999 V70 T5
- Been thanked: 33 times
you'd definitely notice if there were no clamp on that hose. the big hoses blow off under boost if they're insufficiently clamped.
So tomorrow I will be checking the rest of the brake components once again. It seems like the shims are the most common fix for this problem, based on what I have been reading. I would really hate to throw money at items that don't need fixing..unless its preventative maintenance of course
JRL
- Year and Model: Several
- Been thanked: 16 times
REAL NICE R
Nothing there out of the ordinary and much better than your average near 18 year old R!
If you're not sure have a mechanic go thru your rear brakes, rear rotors and E-brakes to find the problem
Thanks! I will make sure to do that today and report back to you guys on what the problem was. I might also do the timing belt just to be safe. Records show the tensioner was replaced at 127k, but not the actual belt itselfJRL wrote:REAL NICE R
- jreed
- Has thanked: 352 times
- Been thanked: 192 times
Gorgeous car!
About 4 years ago I had a terrible vibration on the rear brakes too (on my '97 855), and I replaced the rotors and pads and installed the stainless steel 'half' shims all at the same time. I used ATE rotors and Volvo blue box pads. The vibration problem was solved and hasn't come back... I couldn't tell if it was due to replacing the rotors or installing the shims, or both.
Thank you. I will look into making those repairs as well and reporting back. Hopefully it cures it..it really makes the car sort of annoying to drive.jreed wrote:Gorgeous car!
- 1745 Views
- 1953 Views
Last post by SuperHerman
