97 850 T5 - Stalling, hard starting MVSOLVED dist rotor bolt Topic is solved
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 20 times
Post by jblackburn »
Sounds like a typical MAF sensor to me, however, check all turbo air hose connections for something loose as well - they easily blow loose from the clamps once the rubber gets old.
'98 S70 T5
2016 Chevy Cruze Premier
keithf
Year and Model: 1997 850 T5
Post by keithf »
My code reader showed up yesterday. Unfortunately, the only codes captured were the misfire codes from a few weeks back: P1310, P0301, P0300. I've reset the codes, run the engine to operating temperature, but no new codes are showing up.
Additional troubleshooting:
- disconnected the MAF, which makes start to idle rough
- checked out the fuel pressure regulator - looks ok, no gas came out of the vacuum line. When I disconnect it, the idle changes.
- measured 12v & 5v at the Cam Position Sensor (note: the electrical connector on the cam sensor is brittle.)
- rechecked gaps on all 5 plugs
- did another look for broken lines, hoses, etc...
- realized that it starts easier when cold. After it warms up, it's more difficult to start.
I'm thinking that it's either the Cam Position Sensor or the Crank Sensor. I'm likely going to order both, and throw in the towel (tow it to my local Volvo specialty shop) if that doesn't fix it.
I'll let you all know what happens.
1997 850 T5
2007 S60 T5
2009 S60 2.5T
850_olaf_nz
Year and Model: 1997 855-T5
Post by 850_olaf_nz »
more difficult to start when warm? could the CTS be having something to do with this?
edit: sorry, must better explain my thinking - when it's warm, where's your temp gauge? if the cts is mis-representing temp to the DME (eg reporting cool) it could be running too rich & contribute to your difficult starting. I've experienced this before. replaced cts at same time as MAF, and recently replaced failed CTS (5 years later) with genuine volvo part.
HTH
1997 855-T5, 182k km, as stock as a stock thing.
E Showell
Year and Model: ‘07 S80 3.2
Has thanked: 37 times
Been thanked: 112 times
Post by E Showell »
Assuming CTS = coolant temperature sensor. You've got me mystified with DME, however.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
850_olaf_nz
bmw-speak. DME = Digital Motor Electronics aka Bosch Motronic. sorry for any confusion!
yep, it's probably the cam position sensor (having slept on it some more) making the startng difficult when hot.
keithf
Post by keithf »
This is finally solved, though it was quite a random problem. The distributor rotor bolts had come loose, essentially creating a spark/timing issue. I guess a few months ago when I replaced the cap and rotor I didn't torque the rotor bolts down enough. While the solution was really simple, it took way too much time (and money) to find the cause. Lesson learned -- Double check torque on everything.
During my troubleshooting the problem went from "difficult to start and stalling" to "non-starting". That's when I gave up and had the car towed to a local Volvo specialist. They had the car for a week and put a lot of hours into solving it. Thankfully, they only charged me for a couple hours, as they were intrigued and took it on as a challenge.
1997 850 T5
2007 S60 T5
2009 S60 2.5T
jblackburn
That's something no one would have ever thought of!
Glad they were able to get it running again!
'98 S70 T5
