2002 S60 Issue With Axle When Replacing Control Arm
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
xHeart
Year and Model: 2.0/3.2
Has thanked: 113 times
Been thanked: 115 times
Re: 2002 S60 Issue With Alxe When Replacing Control Arm
Post by xHeart »
precopster wrote:I've installed ball joints on P2s by using a large galvanised water pipe cut square at the end with burrs filed off and a plastic sleeve inserted to protect the rubbers. If you're using quality ball joints (Febi, Lemforder, Meyle etc) they will go in with not too much effort.
However I used Karlyn on one job and they wouldn't go in squarely on both sides after repeated attempts and they were fitted with a small .5mm gap from the mating surface. Online feedback about Karlyn joints suggests the same results.
I can speak for Lemförder - a good fit.
velorider
Year and Model: 2005 S60 T5
Has thanked: 2 times
Been thanked: 26 times
Post by velorider »
Getting in was less of a worry then removing. I can't see how to remove them. The Volvo directions suggest a special tool that looks like a slide hammer, but I only have a jack so I can't raise the car enough.
Any secrets to removing them would be appreciated.
Thanks
John
regent
Year and Model: 2015 XC60 T5
Been thanked: 12 times
Post by regent »
SAFETY FIRST: Do not use a slidehammer or any high impact tool with the car on jack stands!
Take the steering knuckle off, remove the side bolts holding the BJ to knuckle, and then use a slidehammer to remove the BJ. It took me like 3 minutes per side once the knuckles were off. (I rented this Slidehammer from Autozone for free: http://www.autozone.com/autozone/access ... id=2831515)
To istall the BJs, I used Mike's method (with a 6" piece of steel conduit, nicely deburred); my BJs came equipped with protective plastic covers as they were Lemförder. Before istall, clean the mating surfaces thoroughly and lube the BJ seat in the knuckle with bearing grease lightly.
Do not forget to measure and record the strut to steering knucle distance prior to disassembly. When done with the BJs, you will have to reinstall the knuckles in the same positions to maintain camber.
2015 BMW 335i
2015 XC60 T5 Premier Plus
2002 S60 2.4 n/a - retired :(
1987 340 DL - retired :(
