94 Volvo 850 T5 - Time to replace rear suspension bushings?
Volvofan94
Year and Model: 2002 Volvo S60 AWD
Re: 94 Volvo 850 T5 - Time to replace rear suspension bushin
Post by Volvofan94 »
The how to writeups are very helpful. Thank you! Now I need to build up a little courage to do it. :lol: Looks pretty involved and it would definitely be a first for me. I would replace the end links and delta links while the rear axle is taken all apart. Hopefully it will leave me with some more room to replace the aging flexible brake lines as well.
Hoping for a long fall this year because I wanted to replace the timing belt, tensioners, and water pump too. :mrgreen:
2002 Volvo S60 AWD - 2.4L I5, 167k miles - Daily Driver
1994 Volvo 850 - 2.3L I5, 160k miles. - SOLD
1994 Volvo 850 - 2.4L I5, 174k miles. - SOLD
Volvofan94
With the summer sales coming to a close I'm more interested than ever to replace my delta end links. Do you recommend the OEM Volvo ones ($180 a piece) or can I get away with the version that is easier on the wallet ($36 a piece)?
I'm sure OEM Volvo is preferred, but just curious on how the other ones have held up compared to OEM.
Thanks everyone!
Year and Model: Many Volvos
Been thanked: 75 times
Post by Ozark Lee »
I used the Scan Tech version several years ago and after 150k miles or so they are still fine. Things change rapidly in the parts world and I don't know if the current offering is any good or not.
That is the one and only Scan Tech item that I have ever used and been happy with.
Reinie
Year and Model: 1999 S70
Post by Reinie »
My 1999 s70 delta end-link (rear passenger) started thumping at slow right hand turns, mostly when leaving driveway approaches. The rear of the car was also not level, leaning slightly toward the driver side. Mechanic said rear was not out of alignment, but the tracking was greatly improved after replacement. Must have been related to the uneven geometry of the torsion axle. All other components did not need replacement. Had to bring it to a frame shop, my usual mechanic saw too many potential problems. Cost $425.00
Volvofan94
Sorry to revive an old thread, but I wanted to provide an update and ask a question. :D
I got the delta end links replaced on the Turbo and I notice a difference in how my car rides and handles. Much improved!
Although, one small issue has appeared. After the new end links were installed the rear tires rub along the inner fender liner when I pull into a driveway. The area is closest to the frame and rear bumper on both sides. This evening will provide a picture later for reference. Before replacing the end links the rear tires didn't rub against the fender liners. I have 18" Pegasus wheels installed currently. The rubbing sound is gone in normal driving situations unless the car is in a turn and leans to either side.
Would pushing down the trailing arm when removing / installing the end links cause this?
-volvofan94
RussB
Year and Model: '00 S70, '04 S60
Has thanked: 3 times
Post by RussB »
Did you have it aligned after installing the trailing arm bushings?
'00 S70, '04 S60 and the never ending quest for Stage Zero
codeguardiola
Year and Model: 850 1996
Post by codeguardiola »
I have an 98 volvo turbo 850 automatic. That I was looking at suspension on. Does anyone know where I could get coilovers for it? Or what's some good ideas?
Volvofan94
The car hasn't had an alignment yet... Is an alignment needed after replacing the trailing arm bushings too?
I thought an alignment was required if I replaced the transverse arm bushings. Decided to wait on those until they were needing replacement.
Volvofan94
I looked at Lee's guide again and yes an alignment is recommended. I'm sorry guys. :oops:
https://www.matthewsvolvosite.com/forums ... hp?p=31294
I will call the alignment shop tomorrow morning and report back if it fixes the issues. Good news is my rear tires seem ok and not overly worn down.
tryingbe
Year and Model: None
Has thanked: 1 time
Been thanked: 26 times
Post by tryingbe »
codeguardiola wrote:Does anyone know where I could get coilovers for it?
I have ksport on my car.
http://ksportusa.com/b2c/proddetail.php?prod=CVO030-KP
85 GLH, 367 whp
00 Insight, 72 mpg
