1996 850 GLT Radiator Replacement Troubles
Has thanked: 1502 times
Been thanked: 3813 times
Re: 1996 850 GLT Radiator Replacement Troubles
Okay, it's coming back to me.
Both of the 13mm bolts snapped off when I went to remove. I removed the nuts on the engine mount which unscrewed the snapped-off threads
I put a stainless 13mm nut bolt on each side to replace.
shillings55
Year and Model: 850, 1996
Post by shillings55 »
I ended up having to dremel off both bolts. The passenger side I did from the bottom. The driver side was miserable because there are components in the way on the bottom and so I had to chop away at the top nut little by little.
I ended up replacing the parts with some bolts and washers from Napa.
Found some new retaining clips at Napa too that also required new, longer bolts from the hardware store.
I thought this repair was supposed to be easy!
dosbricks
Been thanked: 2 times
Post by dosbricks »
It's pretty easy if you don't live in the wintry northern states where they use corrosive road salt. The bolts came out without any problem on our cars. Not bragging, just feeling lucky. Ben must have bought his wagon somewhere down South. :wink:
Thanks for reporting back. Glad you got 'er done.
Atis
Year and Model: S70 GLT 1998
Has thanked: 1 time
Been thanked: 4 times
Post by Atis »
I have run into the same problem and did it with a Dremel (only on passanger side, from below).
Since then I apply penetrating oil on every screw...
