1999 V70 Ridiculously Rounded Drain Plug Advice
rmmagow
Year and Model: V70 1998
Been thanked: 2 times
Re: 1999 V70 Ridiculously Rounded Drain Plug Advice
Post by rmmagow »
Plus you can bang the pipe wrench with a little sledge for assistance.
1998 S70 135K - FOR SALE
2003 GMC Sonoma - 114K - POS
Has thanked: 1500 times
Been thanked: 3810 times
Pipe wrench with like new sharp teeth. Maybe even go the Harbor freight for a new one for this job.
It might also yield to a chisel being applied to the tangent, if you have good hammer technique.
RussB
Year and Model: '00 S70, '04 S60
Has thanked: 3 times
Post by RussB »
I would put some heat to it, and try again with vice grips or channel locks
'00 S70, '04 S60 and the never ending quest for Stage Zero
A vice grip with curved jaws placed on the 1230 and 630 position on your photo should do the trick.
You need to get them tight, though. Bring the tension screw down until the grip touches the plug, then unlock and give it two full turns in. You might even need channel lock pliers to close the vice grip.
There is a lot of oil around there to use flame , and it is going to be hard to heat that metal with all the oil in the crankcase, too.
kallekula
Year and Model: S70 2000
Has thanked: 58 times
Been thanked: 75 times
Post by kallekula »
Try this
BMW 540i 2002
S70 Base 2000
deepsouth
Year and Model: 2001 Volvo XC70
Been thanked: 8 times
Post by deepsouth »
The above video "may" work if there was room to actually spin that large of a tool. It's a very tight area.
Pipe wrench same deal--seems to be too much missing to grip on to. I've spent and exceedingly frustrating amount of time on this stupidly simple problem. (And unleashed a string of profanity that's fitting of a WWII sailor.)
Not sure about heat due to presence of so much oil and not sure it would even get hot enough to do much.
I haven't yet given up on the vise grips and I'm also locating a set of Nutbuster Chanellocks and going to attempt to file down the bolt. Very much appreciate all the ideas!
2000 S70 GLT SE, 175,000
2001 XC70, 129,000
regent
Year and Model: 2015 XC60 T5
Has thanked: 2 times
Been thanked: 12 times
Post by regent »
Try cold - a couple dabs of liquid nitrogen on the plug's head - and then immediately apply the "chisel tangent" approach. Make sure you wear glasses, gloves, and long sleeves.
2015 BMW 335i
2015 XC60 T5 Premier Plus
2002 S60 2.4 n/a - retired :(
1987 340 DL - retired :(
We want a picture of this thing once it is out....
Keep at it, we are pulling for you...
:D :D :D
Ben850
Been thanked: 7 times
Post by Ben850 »
I've used a hacksaw blade with a handle to cut a slot across the head of a bolt or screw, wide and deep enough to put a large screwdriver blade across. be sure to cut it so the direction you need to go has room to move the shaft of the screwdriver.
A sawzall works well if there is room.
1996 850 Turbo Wagon White.
1994 850 N/A Wagon Black.
1997 850 Sedan Black.
1996 850R Wagon White.
JimBee
Has thanked: 25 times
Been thanked: 42 times
Post by JimBee »
This pipe wrench would be my weapon of choice:
http://www.harborfreight.com/8-inch-ste ... 39641.html
I have the small and medium sizes of pipe wrenches and for the occasional need they're fine, even though the teeth a kind of smoothed off.
For what you're struggling with I'd buy a new one, like the HF number above. New, their teeth are sharp and harder you pull on it, the more the teeth will dig in. Worth a try.
If I absolutely couldn't get a grip, I'd try to hit it with my dremel tool to recut at least one angular edge so the wrench would have even more to bite onto.
