00 S70 GLT All warning lights on
- FLXC90
- Year and Model: 98 V70 T5
- Has thanked: 16 times
- Been thanked: 45 times
Pedal sensor problem for ETS Light on but ignored, car ran rich, sooted up your after-cat O2 sensor, (just changed mine, looked like a charcoal briquette) probably interconnected. ABS stuff all tied together with upshift arrow. Or could that be a Vehicle Speed Sensor issue?
Current Volvos:
rmmagow
- Year and Model: V70 1998
- Been thanked: 2 times
Check that B+ cable and perhaps the Voltage regulator.
1998 S70 135K - FOR SALE
2003 GMC Sonoma - 114K - POS
neworleans
- Year and Model: 2007 S60R
Sent the Module to Matt last week and got it back yesterday, installed it, when started only the check engine light came on along with the flashing arrow, a couple minutes later the arrow light went off. Scanned it and only showed P1618, tried to erase the code but no success. Did some research on the code, do you guys think I should take it to the dealer to have it erased?
- Has thanked: 1611 times
- Been thanked: 4075 times
Have you tried disconnecting the battery for 30 minutes to clear that last code?
rmmagow
You also might want to do as abscate says but while the battery is disco'd, remove the TCM (I think it should say ASIN someplace, check the pins/connections, maybe spray with electrical cleaner and reseat a couple of times to clean up maybe a dirty connection. You might want to do this with the ECU too while you're in there.
neworleans
I will try that tonight, but i had it disconnected before removing the module and connected back again when installed back.
- 2746 Views
Last post by mydamnvolvo
- 2030 Views
- 602 Views
Last post by foggydogg
- 2001 Views
- 1239 Views
Last post by regent
