Help with general volvo knowledge please.
pate6
Year and Model: s70 1999
Post by pate6 »
It says volvo s70 t5 on it.
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
pate6
Post by pate6 »
Both of those videos where very very helpful. Thank you I need to replace my pcv and another question I have is. If my air temperature sensor is plugged in my car boggs out at roughly 3k rpms and wont go over and also has a hesitation at take off but if I unplug that sensor it drives down the road great with no bogging loss of power or hesitation but it idle hunts really bad at a stop because there is a big hole in the air intake where the sensor belongs. Would the sensor being bad cause all that or do I have another issue? I went ahead and ordered a new sensor it should be here on the 30th. Also I belive my electric throttle module is going bad any recommendations on that? I have seen some on ebay and everyone has a date in the description. What exactly it this date? And there a bit price does anyone have one or know someone who has one they will sell a little cheaper? Thanks again everyone.
Year and Model: Many Volvos
Been thanked: 76 times
Post by Ozark Lee »
Is the ETS light on? If not, your throttle module is probably OK or perhaps just dirty. If you clean it try to avoid solvent on the position sensors on the end and also avoid drowning the rod for the butterfly valve on the inside. Carb cleaner hastens the demise of the sensors if it penetrates the cases.
Deal with air leaks first and see where that gets you. Used throttle modules may or may not work without a software download. The best module to get is an XEMODEX converted ETM but beyond that you want a yellow sticker version. The white sticker versions are real bad and should be avoided.
pate6
Post by pate6 »
My ets light is not on so im going to try cleaning the module on Tuesday after work and replacing the air temperature sensor on Thursday and I found the stamp on thw back of the block but ill have to clean it off tomorrow after work to read it. Ill let all you guys know how everything goes. And thanks for all of the information you have been extremely helpful. I appreciate it.
pate6
Post by pate6 »
Me and phil cleaned my etm ran better but still rough so we unplugged the maf and she ran great so I just need a new maf thank you all for the help with this problem.
jimmy57
Has thanked: 5 times
Been thanked: 322 times
Post by jimmy57 »
After all the engine issues get resolved you need to get the strut top hardware fixed. The washers on top of the struts are upside down and the T nut that should be below the washer is missing. The way it is assembled now will make the ride harsher and much noisier.
phils94850
Year and Model: 2009 s60 turbo
Post by phils94850 »
Jimmy thank you for pointing that out, I didn't pay attention to it, been focused on getting her running right. I think we finally got her figured out.
1996 Platinum Edition
pate6
Post by pate6 »
Thanks jimmy I didnt even notice that until you said something. That has probably condoned tho the reason I need a new cv. And I cant go over 60 because that tire bounces all over the place. Thank you for pointing that out.
Has thanked: 2199 times
Been thanked: 1851 times
Sorry for taking so long to read this interesting thread.
Looking at the picture you posted, there also looks like oil leaking from the union between the power-steering reservoir and the rubber pipe running to the back of the engine. It looks like there is no pipe clamp on the pipe! Maybe I'm just imagining it?!
Good luck with your project!
