1998 V70 Timing Marks are Way OFF ? Was running fine.
mecheng
- Has thanked: 15 times
- Been thanked: 21 times
I don't think you would get a CEL on a 98, maybe 99+
1997 Volvo 850 GLT - 190km
Boost is my drug of choice
- misha
- Has thanked: 155 times
- Been thanked: 432 times
Meybe he didn'got a cel because both of the cams were 2 teeth off.They were synchronised.
He would have cel if only one of the cams or crank was up to 3 teeth off.
Even 850 would throw a cel for incorrect timing.In fact...every ecu controlled engine.
Ecu will try to compensate but it will inform you about that with a cel on.
His ecu was remaped by IPD,maybe that is the reason why his car didn't throw a cel.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
villagepc
- Year and Model: 98 V70m | Stage III
- Has thanked: 3 times
- Been thanked: 2 times
Here's a pic facing both cams with bolts visible.
____________________________________________
1998 V70 T5M R Clone | IPD / ARD Stage 3
2008 S80 3.2 - not too shabby
1991 740 Turbo - 2.5" lift, 100% madness
villagepc
Installed new belt / serp belt etc - car runs fine. Aligned timing where it is supposed to be. I will say, I feel more power in the bottom end now - before 2500rpm. Guess it just happened to slip the teeth and I never noticed the difference in power since I don't beat my car like a dog.
Thanks everyone for their input and quick replies.
On a side note: Do NOT buy your serpentine belts from Advanced Auto Parts. The dimensions they have listed for the belt (length) is incorrect on their website AND in their computer system. Sold me a 72.5" belt when I needed 69 (68.5 fits but its snug).
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
Thanks for the update. Glad you have better power curve.
mtd240
- Year and Model: 2007 XC70
- Has thanked: 23 times
- Been thanked: 7 times
Glad to hear you worked out the timing issue.villagepc wrote: On a side note: Do NOT buy your serpentine belts from Advanced Auto Parts. The dimensions they have listed for the belt (length) is incorrect on their website AND in their computer system. Sold me a 72.5" belt when I needed 69 (68.5 fits but its snug).
I *believe* the serpentine belt routing changed sometime during the late 90s for 850/S/V70s to give more surface area on the alternator. Wait for response from one of the folks more versed in this particular Volvo..
2007 XC70, white/oak, 175k miles
2008 XC70 3.2L, 115k miles
2016 XC60, osmium grey / off-black, 95k miles
Gone:
1990 240 DL Wagon, M47, lots of goodies. 372,000 miles
1978 242, lots and lots of work to get a reliable daily
1998 V70 XC, Almost done replacing everything, then I sold it
1996 850 NA, victim of sporadic tree falling. Protected the wife. RIP Volvo
Gone:
villagepc
Correct - there *are* 2 ways to route the accessory belt. I used the newer routing, which comes to aprox
69 inches.
Thanks again, ya'll are awesomes!
69 inches.
Christiang19
- Year and Model: 1999 s70
It's possible you may need to replace the crank pulley.
If the layers separate or slip due to a worn harmonic balancer, the timing marks, which are usually stamped into the front of the pulley, can shift and thus throw off the placement of the timing marks.
- mrbrian200
- Has thanked: 7 times
- Been thanked: 84 times
He was lining the crank up by the marks on the timing belt sprocket, the harmonic balancer/pulley isn't in play.Christiang19 wrote: 11 Dec 2017, 15:17 It's possible you may need to replace the crank pulley.
Villagepc, has your econ perked up since you corrected the cam timing?
- FLXC90
- Year and Model: 98 V70 T5
- Has thanked: 16 times
- Been thanked: 45 times
OP- did you have this car tuned or did PO? Cams may have been retarded to move the torque curve, and could be part of the remap. Do you have any paper on the build? IPD may be able to tell you what was spec'd if you can give a P.O. number or ECU number.
Current Volvos:
- 22 Replies
- 34557 Views
Last post by jmartin919
- 10629 Views
Last post by vtl
- 1740 Views
Last post by dsharp
- 15 Replies
- 6388 Views
Last post by wizechatmgr
- 1816 Views
Last post by ksdst1
