I managed to get the connector undone and re-connected so that hurdle is overcome. Removing the long rods or nuts to get the bracket off isn't working out so your idea of loosening the main mounting bolts seems like the best option. Thanks Neil!scot850 wrote:Mike knows how much I cursed when I tried to remove that connector on my car. Eventually tearing off half of my thumb-nail in the process. Use plenty of either silicon spray or WD40. You have to push down on the tab in the middle between the 2 fingers in the picture to release the tab. With dirt, heat and time the connector becomes a devil to undo. Just work on it with time and patience. I used 2 pairs of adjustable pliers to give me more grip.
The 2 rods in the starter motor if you undo them will allow the starter motor to separate and come apart. I gave myself some room and just loosened the 2 main starter mounting bolts enough to allow it to move enough to let the wire come out from behind the motor.
Bob
