1995 855 Stripped rear O2 sensor
lcc014
Year and Model: 855, 1995
Has thanked: 2 times
Been thanked: 11 times
Post by lcc014 »
JDS60R wrote:Get a straight metal file and file down the edges of the sensor and install the next size down deep socket ( you may have to cur off the leads. Or, grab some map gas and a good vice grip or a plumbers wrench. heat up the bung (concentrate on the bung not the sensor and turn it orange ( the sensor will also be a dull orange. Then turn it out. ( have fire equipment handy.) Or - buy a cheap 7/8 or 22mm socket and weld it onto the sensor in a few spots. Let the heat soak in while welding. Then turn it out
Thanks for the advice. I have no welding tools. I could try the map gas to heat up the "bung". What is this "bung", BTW ?
Thanks.
JDS60R
Been thanked: 3 times
Post by JDS60R »
Bung is the piece of metal that has the threads for the O2 sensor to screw into. The bung is welded to the pipe so you can insert the O2 sensor into it.
welded in bung.jpg (55.94 KiB) Viewed 803 times
Retired
lcc014
Post by lcc014 »
JDS60R wrote:Bung is the piece of metal that has the threads for the O2 sensor to screw into. The bung is welded to the pipe so you can insert the O2 sensor into it.
Great picture and explanation. Thanks :D
db130
Year and Model: 2002 V70 T5
Post by db130 »
buy/borrow a mapp gas torch+vice grips
you want to heat up the exhaust pipe around the o2 sensor(the aforementioned bung and surrounding area) until it glows red(usually takes about ~30 seconds)
2002 V70 T5 169k
2002 V70 NA 249k
2006 Mini Cooper S 90k
lcc014
Post by lcc014 »
db130 wrote:buy/borrow a mapp gas torch+vice grips
I have mapp gas torch and vice grips. Definitely give it a try. Thanks.
