1998 VOLVO v70 xc Misfire Ignition problem
Ludermilch
Year and Model: 98V70XC 98V70R 01C70
Has thanked: 1 time
Post by Ludermilch »
Curious, I swapped out the coil to see if that worked. Still same problem. I have a fuel pump relay, is this the same as the injection relay?
1998 V70XC
2001 C70
1998 V70R
2000 Subaru Outback VDC
Perception Fontana Tandem Kayak
Ludermilch
Has thanked: 1 time
Not new cords, about 2 years
1998 V70XC
2001 C70
1998 V70R
Ludermilch
Has thanked: 1 time
I did discover the PCV valve connector not plugged in. Helped some.
1998 V70XC
2001 C70
1998 V70R
Has thanked: 312 times
Been thanked: 818 times
Post by erikv11 »
Fuel injector relay is different, it is a gray one under the fan shroud.
Ludermilch
Has thanked: 1 time
Unable to find anything but the fan control and a vacuum solenoid, I was able to drive to Missouri. It isn't misfiring as often and I am under the impression that it is a fuel related problem.
1998 V70XC
2001 C70
1998 V70R
Post by erikv11 »
I just looked at my s70 you are right no fuel system relay there, I didn't realize the engine wiring harness was different there from an 850.
I couldn't find it, either there isn't one or it is tucked away somewhere else, the 850 part looks like this:
Ludermilch
Has thanked: 1 time
Made it back home. Now to figure out what is going on.
1998 V70XC
2001 C70
1998 V70R
Ludermilch
Has thanked: 1 time
After much debate on what was causing my headache on my trip I have concluded it was the ignition cords aggravated by the thin air and heat. They were barely 2 year old cords but not Bougicord. Guess what. After returning home and visiting a local P&P, I found a new set of Bougicords on a car and put them on my wagon and all misfires went away. Thank you to all who weighed in on my problems.
1998 V70XC
2001 C70
1998 V70R
Has thanked: 1611 times
Been thanked: 4075 times
Thanks for closing loop on this, I've changed thread to solved with solution.
Yet another case for Bougicord plug wires on these cars
