1994 850 Turbo Running rough and threw a lot of codes
I used a stethoscope to check if the injector on 3 was working by listening for the clicking. 3 sounded like all the others. I already had the PCV kit for it so this weekend I'm going to tear into it and hope that the intake mani gasket is torn at cylinder 3. I guess I'll borrow a compression checker at the auto parts store also.
'96 855 NA 269,000
'94 854 Turbo 162,000 rebuilding the head after a burned valve
'95 854 Turbo parts car
'03 V70 XC 142,000
'04 V70 NA 230,000
'04 S60 NA 152,000 oldest daughter's car
2005 Mazda 5, 5sd 163,000
2001 Excursion 7.3 power stroke 135,000
'03 V70 XC 142,000
'04 V70 NA 230,000
- Has thanked: 311 times
- Been thanked: 817 times
So you have examined the injector electrical, nice work. An injector ticking is not the same as an injector dispensing fuel though, e.g, it could be clogged, swapping them around will test that.
I would just check the compression before tearing into the PCV. If compression in #3 is zero or very low, you may want to contemplate your options.
Okay. Bad news. Zero compression in the number 3 cylinder. Dry test compression #1-165, #2-159, #3-0, #4-145, #5-144. So I noticed on a previous post someone mentioned that they pulled there head and took it to a machine shop to have a valve job done on it for $225. Does anyone know if this is still about the right amount? I know there will be regional differences. I'm in southern Oregon.
Also, I have a parts car that is a year newer, same 850 Turbo. I know I will be rolling the dice as to what type of compression it has (I've taken to my things off it already to turn it over and check the compression). We need to get this thing going before my daughter goes to school at George Fox in 2 weeks. Or else she will take my wife's car and I will have an unhappy wife, who is already mad at me because I chose to by this car.
I would only need a new head and valve gasket, right? Or just a head gasket if I can remove the head with the valve cover on it.
Sorry if this sounds stupid, I just muddle my way through things.
Thanks everyone, Shannon
'96 855 NA 269,000
'03 V70 XC 142,000
'04 V70 NA 230,000
'03 V70 XC 142,000
'04 V70 NA 230,000
At this point would doing a wet compression test help?
'96 855 NA 269,000
'03 V70 XC 142,000
'04 V70 NA 230,000
'03 V70 XC 142,000
'04 V70 NA 230,000
Quick wet compression to rule out rings is smart.
Getting it back on the road in two weeks is tough, your shop will need that much time if they are any good ( because they will have backlog of work)
What if just I put the head from my parts car on without sending it to the shop? I know it's a gamble and I would only be out my time. It worked great before I tore it. The AC compressor seized and the previous owner had a hobby mechanic try to bypass the compressor with the serpentine belt and it was just to slack.
'96 855 NA 269,000
'03 V70 XC 142,000
'04 V70 NA 230,000
'03 V70 XC 142,000
'04 V70 NA 230,000
I want to but I'm running out of time and money. I guess she will be going with my wife's Mazda 5 and we'll have to bring her car up to Portland when its done.
'96 855 NA 269,000
'03 V70 XC 142,000
'04 V70 NA 230,000
'03 V70 XC 142,000
'04 V70 NA 230,000
Take the time and do it right. Then you get a car that runs for 4 years.
Abby will take my T5 to college this fall, 99'miles from home. It's great that basic AAA covers 100 mile tows
- Year and Model: Many Volvos
- Been thanked: 76 times
It is worth a shot so long as the parts car is a turbo. I would get a good straight edge and check it for true before I installed it but if it is flat it should work fine. The only difference in the head between a turbo and a N/A are the exhaust valves. The valves are the same size but the turbo has sodium filled exhaust valves to try to keep them from burning.GDiode wrote:What if just I put the head from my parts car on without sending it to the shop? I know it's a gamble and I would only be out my time. It worked great before I tore it.
Replacing a head is a decent sized job and the ancillary costs are not insignificant so I always try to do it as right as I can and send the head out to the machine shop but that is just the way I'm wired. You may not get another 200k out of it but it should work.
- 203 Replies
- 10471 Views
Last post by volvolugnut
- 11 Replies
- 2808 Views
Last post by Stark77
- 1222 Views
Last post by kmaninaustin
- 13 Replies
- 4146 Views
Last post by 93Regina
- 12 Replies
- 1565 Views
Last post by jonesg
