2001 C70 Is This A Good Year to Purchase?
JRL
- Year and Model: Several
- Been thanked: 16 times
Do not forget, 2001 have the bad MM ETMs
- E Showell
- Year and Model: ‘07 S80 3.2
- Has thanked: 37 times
- Been thanked: 112 times
ETM is a permanent $500 fix.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
'95 855 auto (sold)
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
I probably means the car had a second owner for about 15000 miles who did no maintenance.perks1 wrote:It looks like all maintenance was done regularly -- but we didn't see records for about the last 15,000 miles -- although we did not look too closely, just a quick cursory glance, so we could have missed them.
The manual transmission has a very common and costly slave clutch issue cylinder, check out European forums such as http://volvoforums.org.uk/ where manual transmissions are the norm
Cees Klumper
- Year and Model: 2002 S80 T6
- Has thanked: 46 times
- Been thanked: 33 times
The turning circle will be the same with 16 inch wheels - VERY wide. The noise on sharp turnin-in can be two things I think: either it needs a lick of grease on the plastic steering limiter pad (a 2 minute 'job') or a worn outside CV joint (not likely with such low miles).
- E Showell
Have you bought that car yet?
'95 855 auto (sold)
'95 855 auto (sold)
- Been thanked: 4064 times
Manual transmission in/out listed as 8 hours labor on the books.oragex wrote:I probably means the car had a second owner for about 15000 miles who did no maintenance.perks1 wrote:It looks like all maintenance was done regularly -- but we didn't see records for about the last 15,000 miles -- although we did not look too closely, just a quick cursory glance, so we could have missed them.
Clutch plate
slave cylinder
RMS
probably a 1200 bill at an independent. Not a bill to wish on anyone, but worth it for a good running car.
- E Showell
The suspense is killing me (or perhaps us, but I don't presume to speak for others unless hired to do so).
'95 855 auto (sold)
'95 855 auto (sold)
Thank you all so much for your input and insights. Sorry to keep folks in suspense... I am still deciding -- mostly because I worry there will be hidden expensive problems and right now, I don't yet know how to do any work myself. It really did drive like a dream though -- but still daily driving using a manual to commute in bumper to bumper traffic may be too much.... I spoke to a couple of Volvo mechanics today and they told me that brakes can go soft from air getting in and that it was likely an easy fix and that the cable in the hand brake was likely just stretched. One suggested a brake flush as apparently condensation is quite common on these cars and that will remove it. The stop sets (right word?) in the wheel are likely making that noise on the right. They were more concerned that the airbag light was on and that the owner had turned down fixing tie rods 15-20k ago -- as now the front wheels (particularly the right) are quite worn (the side where the noise is coming from) and those could be bigger problems. I guess I need to decide if I want a mechanic to look at it. I also test drove a 1994 BMW 530i yesterday and really like that, too with lower miles, one owner, all maintenance records, etc. which did not seem to need much upfront work at all. A very different ride but also delightful. So, still making a decision regarding next steps.
In response to ascate's comments, I don't know what happened during the last 15k miles but the title is still under the original owner.
- dosbricks
- Year and Model: '96 855, '98 S70
- Been thanked: 4 times
Many people, when they decide to purchase a new car in the next year, will just stop doing maintenance. If the the car was bought at auction by a wholesaler, then it was very likely traded in at a non-Volvo dealer who may not know much about the mark and therefore be leery of unknown issues.perks1 wrote:....In response to ascate's comments, I don't know what happened during the last 15k miles but the title is still under the original owner.
Thanks dosbricks. The was actually donated to a charity auction, where the wholesaler purchased it but you could still be right. But since there are no records, we don't know. I tried to call the owner as he had an unusual name, but was unable to reach him.
- 2044 Views
Last post by oragex
- 1089 Views
Last post by adrian825
- 2775 Views
Last post by TheMrFailz
- 1047 Views
Last post by 850forum
- 7539 Views
