1998 v70 Hot air through vents
chexny
Year and Model: 1998 V70r
Re: 1998 v70 Hot air through vents
Post by chexny »
abscate wrote:Volvo heater cores always flow full. They are always hot. The ECC blends air from the either the AC or through the core to regulate temperature of the cabin.
Ill guess either the blend motor is acting up or could the hot air just be outside air from the hood area?
Thanks. It is more than just hot air from hood area imo. It comes in hot..like it is 75-85F outside and the air temp coming from the vents is significantly hotter. It is legitimately hot air and at all speeds for the most part. If the the heater core is always circulating coolant then it has to be that the air is coming across it while hot. I thought it only opened when called.
1988 740 -- Long gone
1998 V70r -- Current daily driver
2004 S60 -- Magically turned into a Toyota Sienna :-)
