Did you do compression test? I imagine if piston rings are stuck engine may get too much gases into crankcase.
Also do same glove test under boost (ask somebody to rev engine up to 2500). Does it inflate?
2001 v70 xc smoke coming out of oil dipstick.
newbieofthenorth2+
- Year and Model: v70 xc 2001
I haven't done a compression test yet. But the glove does inflate (barely) under idle.
Black on black 01 v70 xc automatic.
vtl
- Year and Model: 2005 XC70
- Has thanked: 129 times
- Been thanked: 686 times
There's no vacuum in intake manifold under boost, so PCV has two pressure evacuation circuits: to intake manifold if it has vacuum (at lower revs) and to turbine intake (through PTC) under boost. You checked that first one does not work or does not have enough throughput to eliminate all the pressure. Now check second circuit (under boost), is it able to cope with the crankcase pressure?
vtl
I can bet your engine has stuck rings if it has seen crappy oil and/or long change intervals.
To deal with partially stuck piston rings in my engine I poured Seafoam to cylinders and left it overnight, turning crank (wheel has to come off) +/- 15 degrees from time to time, adding more Seafoam when it dripped to crankcase. Overall engine went through two cans. Oil consumption dropped from 160 ml per 1000 km to 110 ml, and the engine starts more easily.
newbieofthenorth2+
I'll have my neighbour rev it and do the glove test first thing in the morning and post. And post a response.
newbieofthenorth2+
I've never used a product like seafoam. Are you saying that I should remove the plugs and pour it directly down the hole into the cylinders?. Wouldn't that hydro lock the engine? Also. My neighbour had a quart of 'Lucas heavy Duty oil stabilizer' laying around. Since I've heard nothing negative (or too positive) about this product I added a litre today. I'm planning on switching to high mileage oil before the coldweather sets in anyway. (probably be around late sept. Up here). So if it is useless itwont be there very long anyway.
newbieofthenorth2+
Also. Over the last week I've been draining and refilling the coolant with de-ionized water. So far i've run 24 litres through it (with the thermo removed). It's still coming out slightly light green/yellowish. Should I go the next step and add a prestone flush additive?
jerseykat1
- Year and Model: 2001 v70
i would imagine there would be a misfire code or 2 if his rings are stuck. there would also be actual misfiring. If not there might even be a Catalytic efficiency code. This is typically what you get from a engine with low compression dues to worn or stuck rings (though im no expert on volvos), you could actually cause your compression to lower a bit by cleaning the carbon build up off of the pistons.
Do a compression test before you seafoam it. if compression is normal 120-130 ish for turbo (typical specs for forced induction engines, volvos may differ IDK) Than your problem just may be elsewhere.
jerseykat1
stick with synthetic oil. high milage just has a higher zinc content. synthetic oils prevent sludge build up in your engine. thats the way to go.newbieofthenorth2+ wrote:I've never used a product like seafoam. Are you saying that I should remove the plugs and pour it directly down the hole into the cylinders?. Wouldn't that hydro lock the engine? Also. My neighbour had a quart of 'Lucas heavy Duty oil stabilizer' laying around. Since I've heard nothing negative (or too positive) about this product I added a litre today. I'm planning on switching to high mileage oil before the coldweather sets in anyway. (probably be around late sept. Up here). So if it is useless itwont be there very long anyway.
- Been thanked: 4064 times
Don't use dionized, and flush the system by opening the radiator drain while putting water back into the reservoir. It will run pure water in about 15 minutes. Baby sit it the whole time so you don't run your engine dry if the hose flops out, if pterodactyls pick it up, etc.newbieofthenorth2+ wrote:Also. Over the last week I've been draining and refilling the coolant with de-ionized water. So far i've run 24 litres through it (with the thermo removed). It's still coming out slightly light green/yellowish. Should I go the next step and add a prestone flush additive?
After this, shut down, let the water run out, close drain plug, add requisite amount of coolant and top off with either tap or distilled water - appropriate freeze protection for your locale.
- 373 Views
- 13 Replies
- 3449 Views
Last post by alschnertz
- 691 Views
Last post by HerrGruyere
- 953 Views
Last post by precopster
- 2442 Views
Last post by Tannhauser
