Got a code off it: 1-2-1, which is apparently MAF sensor signal. I swapped out the MAF from my donor car and nothing changed. Pulled apart all the air hoses, turbo hoses, vac hoses and reconnected, and no change.
I'm stumped. It runs terrible, won't idle, knocks like a hammer is whanging the turbo. Anything else I can try? Turbo to intake hoses are new 1 year ago from the head gasket job.
'95 850 HORRIBLE knocking after tranny swap - SOLVED Topic is solved
850TurboTurtle
- Year and Model: 96 850T, 05 S80T6
- Has thanked: 12 times
- Been thanked: 5 times
850TurboTurtle
Was your backfiring really sharp and hard, like a hard hammer blow from a big wooden mallet on the engine? That's how mine sounds. Not the long 'firework bang' you hear from a tailpipe backfire. I'm afraid to run it much for fear of detonation harming something.abscate wrote:This sounds a lot like my 1999 did with loose induction. The metering is completely screwed up at idle but kind of works at mid Rpm range ..followed by backfiring and WONK ! Detonation
I wonder if the intercooler could be cracked and leaking air? I didn't remove it for the job, and it was fine before, but who knows.
850TurboTurtle
Thanks dosbricks. I only unplugged them from the wiring harness but left them on the engine. The harness length made it so i could only reconnect the right way. So I think that's not it. Still stumped though.dosbricks wrote:Did you remove the knock sensors?
850TurboTurtle
So, I've listened to the hoses for leaks, checked hoses and electrical connectors, vac lines. Swapped out MAF. Checked injector spray patterns. What else can it be?
Bad ECM?
Timing belt slipped? (Put on new last year during head gasket).
Bad fuel or clogged filter/pump/?
I can't think of anything else to check given the symptoms.
Help!
Bad ECM?
Help!
850TurboTurtle
All 5 look the same, a short puff of fuel in a cone, apparently. I'm guessing this is working normally.
Check fuel pressure at rail to rule out fuel
Check for timing belt slip by turning engine over by hand and confirming marks
We have learned the hard way that you have to remove induction parts to check for leaks, Inspection is not enough
- dosbricks
- Year and Model: '96 855, '98 S70
- Been thanked: 4 times
Most likely an intake leak somewhere as the consensus suggests (assuming you used a new manifold gasket and that is not the source). But (and this is a long shot) since you got a MAF code--certain models had problems with the plug/wireing where it connects to the the MAF.
Some electrical contact cleaner sprayed into the connection and making sure the engine side wiring is secured and can't flex around with engine torque might be worth trying. I have been concerned with the way all the aged wiring must get wooled around to get it all out of the way for my own in progress engine removal. So I'm watching this thread closely and pulling for you to solve this problem.
dos
dos
1ezliving4ume
- Year and Model: 850 glt turbo 1997
In your video it looks like a small puff of smoke comes out of the turbo cold air discharge. The side going to the intercooler. Its around the 12 second mark on your video. Do you see it?
When these engines wonky-run, codes are meaningless. You will get all kinds of spurious stuff popping up if there is a lot of misfiring.
850TurboTurtle
You're right. In fact, I think maybe there are smaller puffs after each knock. Hmmmmmmmm..... I'll have to take a closer look into that. thanks. Good eyes!1ezliving4ume wrote:In your video it looks like a small puff of smoke comes out of the turbo cold air discharge. The side going to the intercooler. Its around the 12 second mark on your video. Do you see it?
- 939 Views
Last post by Ozark Lee
- 1772 Views
Last post by dudeitssm
- 1975 Views
- 27 Replies
- 7825 Views
Last post by Justtellme
- 25 Replies
- 4734 Views
Last post by erikv11
