1: You can't just give up and put it back. If you've loosened it that much, you have to change the gasket.
2: You can't just lift it up, because it will bump against the thingies it's bumping against, which is the reason for your post in the first place.
3: If you can't pull it out to clear those, then you have a) not loosened/removed the bolts enough or b) overlooked one or more bolts.
And yeah, this job is done from up top. No need to get underneath.
- S
1995 850 turbo: edit : Manifold won't come out
Sommerfeldt
- Year and Model: 2018 S90 T8
- Has thanked: 55 times
- Been thanked: 42 times
[Sold] '97 S70 T5
[Sold] '97 S70 T5
- Has thanked: 312 times
- Been thanked: 818 times
YES unfortunately no one has mentioned this but the EGR pipe must be disconnected.volvo850freek wrote:should i just remove the lower four bolts?? does having an EGR mean there's more bolts to take off??
I wouldn't pull the 4 bolts all the way out but it is not then end of the world if you do, at least you can be sure that way.
volvo850freek
- Year and Model: 850/94
thanks, that's what i thought... I didn't realize how much of a hassle this replacement turns into when you throw in an egr. i tried to search more for other people with this issue...anways i was running out of time, I had work the next day and ended up biting the bullet and our family mechanic agreed to finish my botched pcv job...for $250
and yeah he explained that too, and i guess you got to take out more parts just to make room to take out the EGR.
Yeah, a lot of forum posters have never worked on a car with EGR, so do not even think about it even though you mentioned it several times in your posts.
Don't feel bad, the PCV service is a very long job, it's not tricky like a timing belt job but actually requires more effort because there is so much to remove then put back together.
- Has thanked: 1611 times
- Been thanked: 4072 times
Guilty as charged. It is better to get this info before you start the job, though.erikv11 wrote:Yeah, a lot of forum posters have never worked on a car with EGR, so do not even think about it even though you mentioned it several times in your posts.
- 1316 Views
Last post by JimBee
- 677 Views
Last post by billwann
- 3056 Views
Last post by mouseskowitz
- 2028 Views
Last post by joedrt77
- 650 Views
Last post by SVO LOU
