96 850NA Wet Weather Misfire & Stall
FLXC90
Year and Model: 98 V70 T5
Has thanked: 16 times
Been thanked: 45 times
Post by FLXC90 »
Get that timing cover open then. Another leak that was shown on the forum recently was a diverter valve for the piston squirters that screws into the face of the block and has a copper crush washer. In any case, oil and timing belts don't mix for long.
Current Volvos:
eriscentro
Year and Model: 96 850, 01 S60
Post by eriscentro »
I'll look into it later today. The front exhaust seal replacement is essentially a TB job with some fun added on, correct?
Year and Model: 2004 V70 2.5T
Been thanked: 504 times
Post by cn90 »
- FRONT Cam seals are known to leak after 140K-150K. You will see oil at the bottom of the TB cover and CV boot and subframe. Info in the Timing Belt Serp Belt DIY I wrote a while back.
- OEM seal is Corteco, about $8-$10/each.
Re: Ignition department, this is what I use:
- Iridium spark plug by NGK (info in forum)
- Bougicord
- Cap/Rotor: Bosch only.
Once you tune-up the ignition dept, you should not have the "misfire when wet" issue.
cBobs94850T
Year and Model: 850 1994
Post by cBobs94850T »
This same thing happened to me, the solution was a new cap and rotor.
Has thanked: 311 times
Been thanked: 817 times
Post by erikv11 »
eriscentro wrote:I'll look into it later today. The front exhaust seal replacement is essentially a TB job with some fun added on, correct?
Yep, that's right.
The fronts don't leak very often but they don't last forever either, I have had to change just a couple. The rear seals are much more common to need changing because they blow out easily under PCV-related pressure; that is the reason they usually go rather than the seal going bad.
eriscentro
Yep, that's right.
Unfortunately the mechanic who did my TB last year didn't change the seals. I'll have to tackle it around thanksgiving when I have access to tools and space.
Post by erikv11 »
You still want to track down the actual leak before you dive in. In now way at all do the front cam seals fail predictably at any given mileage or age. On most of the P80 cars I have worked with, they are fine. Don't change 'em until they start to leak. You may have a leaky one but you may not, a couple other possibilities have been suggested.
eriscentro
This evening I pulled the spark plug cover and the timing belt cover. I found a lot of oil pooled by the plugs, so I sopped it all up. I have no idea when the filler cap gasket was changed last (has to be 4-5+ years), so I picked up a new cap at the local auto parts store. My old gasket wasn't rock-solid or brittle, but it certainly seemed far harder than the new one. With regards to the leak, I noticed that much of the oil was over by the interface between the spark plug area and the front (seemingly leaky) cam. I have pictures from months ago and there doesn't seem to be a big difference between now and then. If anything, it's slightly more oil. Thankfully, the TB looks dry.
I'll check on the distributor later this week/weekend. Didn't have the time today.
Post by erikv11 »
Yeah this is what I was talking about, it sounds like the oil may be coming from the oil cap, not the cam seal. Clean up the oil up top, see if the leak accumulation goes away. Good chance the cam seal is fine.
firestarterpro
Year and Model: 850 NA - 1995
Has thanked: 2 times
Post by firestarterpro »
I had this problem plague me all last winter. All I had was a vacuum leak.... A sneaky one in the accordion-like air filter housing to the throttle body.
I changed spark plugs, Mass Airflow Sensors, paid shop diagnostics, etc... but it was hidden in the crevice. I sealed it with several clear UPS label pouches while I waited on my replacement in the mail.
._____________,
||------|---||---||__\ \___
\=-(@)-===-(@)-=*B
The proudest owner of a Naturally Aspired 2.4L Volvo 850 Wagon of 1995!!! :o :o :o
94 850 NA Wagon was hit and totalled at 350k :oops:
96 850 NA Sedan sold at 180k :arrow:
95 850 Turbo Wagon sold at 260k for parts :!:
95 850 NA Wagon sold at 220K :arrow:
